Cannot find it in my notes.
What should the bolt torque be when using the original iron Exhaust Manifold/Bolts to an Aluminum Cylinder Head? I know it's gotta be less than the cast iron Cylinder Head number, but by how much? Using Fel-Pro MS9275B gaskets.
I'm not an 'engine builder'; I'm an Engineer. But this issue is a very important one.
Cylinder heads have a lot of [explosive] force that needs to be retained. Whether the head is steel or aluminum, it has to retain the same force. Steel bolts are quite capable of handling those stresses.
However, retaining an almuminum head with steel bolts creates a significant problem: aluminum expands at about twice the rate as steel when temperature is elevated...and cylinder heads do get HOT!
Since the heads need to expand (after being assembled at room temperature), it would be BEST that the bolts retaining that member expand along with them. But steel bolts expand at twice the rate of the heads. So, the steel bolts will place added [compression] force on the heads at the points of contact once they reach engine operating temps.
ARP has dealt with this by having special steel washers that are placed between the bolts and heads for the purpose of assuring accurate torque application. Other builders deal with this in different ways.
I'm diving into this issue so that those wanting to put aluminum heads on their car's engines will take adequate caution by using proper means to assemble aluminum heads with steel bolts. It's important to get this one right so that head cracking/bolt loosening issues do not occur.
I hear ya 71.
These Exhaust Manifold Bolts were constantly loosening. I looked at the washers on these bolts closely this time, and their Lock washer warp, I call it, was totally absent. Time with the heat probably done them in, as far as temper was concerned, so I now replaced them. I'm anxious to see it the loosening will be curtailed for a while now.
ARP does seem to be the Leaders in this racket. I trust them too.
At the proper rated bolt torque (when cold), can the heads go thru a full heat cycle (engine fully warmed up then go back to ambient temp) without any permanent deformation of the bolt (permanent stretch) or permanent deformation of the aluminum under the bolt/washer?
If the head material and the bolt are limited to "plastic" deformation and fully return to the original state after a heat cycle, the bolts SHOULD not loosen.
In many cases, pros will lock-wire or put French locks on the header bolts; but I have never seen anything like that on the head-to-block mounting bolts.
When I'm dealing with aluminum heads or engine blocks I use studs wherever possible. And then I coat their threads with Permatex Aviation Form-A-Gasket so moisture can't get in. And when using bolts I make sure the thread engagement is at least twice the bolt's diameter so a 3/8" bolt would screw in at least 3/4".
I thought about Safety Wire (drilling the bolt heads), but couldn't see an acceptable way to wire them. French Lock concept would work. Are they commercially available for the ram-horn manifold, or would I have to fabricate them?. Wouldn't mind doin' that.
Studs.
I like that idea, as well as the sectional density concept.
