700R4 Conversion
Old Oct 18, 2017 | 10:12 PM
drwet's Avatar
drwet
Originally Posted by Domobomb
Are you sure about that? I think the bow tie overdrive crossmember relocates the parking brake pulley because the stock location interferes with the driveshaft u-joint.
You do need to relocate the parking brake pulley bracket, but that is a simple matter of cutting it off the crossmember and rewelding it in a location such that the cable clears.
Old Oct 18, 2017 | 10:16 PM
drwet's Avatar
drwet
Originally Posted by oVoSanto
In the 1982 section on the rockauto website I found the ENERGY SUSPENSION 31108G transmission mount.
https://www.rockauto.com/en/moreinfo...041185&jsn=580
Is this enough with the 1982 crossmember?
No. There is a bracket that bolts to the frame. The transmission mount bolts to that, and the transmission bolts to the mount.
Old Oct 19, 2017 | 05:17 AM
Domobomb's Avatar
Domobomb
I don't see it on zip.
Here is an ebay link:
https://www.ebay.com/itm/Corvette-19...-/152055827964
Old Oct 19, 2017 | 08:06 AM
71VetteLover's Avatar
71VetteLover
I just put the nylon pulley on the outside of my bracket then stuffed 1/2" washers between the ears. Then used a longer bolt.
Old Oct 20, 2017 | 06:27 AM
2airtime2's Avatar
2airtime2
How does the lockup work if you have switched 12v and ground on A & B? I read that this will allow lockup in 2nd, 3rd, and 4th. Surely if you accelerate at 1/3 throttle it won't lockup in 2nd and 3rd...will it? Or does it lockup in 2nd then stay locked up for the 3rd and 4th gear shifts?
I've got a '92 with 700r4 and it doesn't lockup while accelerating til I let off the gas.
I saw a video on YouTube where a guy put a vacuum switch inline with the switched 12v. Will installing that switch make it work the way I want? (lockup in 4th only if accelerating).
Vacuum switch part # AC Delco 212331
Old Oct 23, 2017 | 03:57 AM
oVoSanto's Avatar
oVoSanto
OK for the parking brake pulley workaround, it seems perfect.
In the pic attached by 71VetteLover, i can't see the the bracket. It's because he is using a '74 like xmember?
Old Oct 23, 2017 | 02:42 PM
drwet's Avatar
drwet
That is not a factory crossmember setup.
