Power steering pump leak @ cap
Old Oct 7, 2002 | 06:17 PM
Stewart's74's Avatar
Stewart's74
Default Power steering pump leak @ cap
It is leaking around the cap. Is there supposed to be a gasket or "O" ring inside the cap? If so I need one cause thats where it leaks. :rolleyes:
Old Oct 7, 2002 | 06:19 PM
vettesite's Avatar
vettesite
Default Re: Power steering pump leak @ cap (Stewart's74)
There's a rubber ring on the inside of the cap. Mine still leaks a little with the ring. Must be the whiplash acceleration.
Old Oct 7, 2002 | 07:51 PM
Paul L's Avatar
Paul L
It should not leak unless you over-filled.
Old Oct 7, 2002 | 09:08 PM
PRNDL's Avatar
PRNDL
Default Re: Power steering pump leak @ cap (paul79)
I was thinking "overfilled" also. I kept chasing a pesky p/s leak and then I stopped overfilling and it stopped leaking and p/s still worked!! DUHHHH!!! :) MJ
Old Oct 7, 2002 | 10:06 PM
Paul L's Avatar
Paul L
Default Re: Power steering pump leak @ cap (MNJack)
The level should be a good 1" to 1 1/2" below the cap.
Old Oct 7, 2002 | 11:13 PM
Jack71's Avatar
Jack71
Try replacing the cap. I wouldn't play with too much. Jim Shea on Power Steering Caps...
http://forums.corvetteforum.com/zerothread?id=161779
To Power steering pump leak @ cap
