brown wire from alternator
Old Oct 16, 2017 | 01:10 PM
manfroni's Avatar
manfroni
Default brown wire from alternator
what does the brown wire that connects to the 2 wire clip on top of the alternator on my 78 do? It is broken, but the car is fine and the battery remains charged. I have noticed that the gen light on longer comes on. Does this wire do anything else?
thanks,
Old Oct 16, 2017 | 04:03 PM
MelWff's Avatar
MelWff
it is part of the charging system to maintain correct charging voltage.
they make the plastic clip with the two wires attached, you cut off the existing one and splice in the new one.
I'm sure if you used a voltmeter you will discover a problem with the output voltage of the alternator.
Old Oct 16, 2017 | 04:20 PM
lionelhutz's Avatar
lionelhutz
It's the wire for the alternator light. The circuit provides the indicator light and it also helps to excite the alternator and initiate charging when the engine is started. The alternator might not work with it disconnected, but in your case it seems the alternator is self exciting.
You can replace the clip, or just the end of the wire to fix it. The terminals are fairly easy to remove from the connector with a small screwdriver or other small thin tab. You just push it in on the side of the connector that plugs into the alternator on the back part of the terminal where there is a little tab that has to be depressed to release it.
Old Oct 16, 2017 | 07:07 PM
71VetteLover's Avatar
71VetteLover
thanks,
The single strand brown wire is what energizes the field and gets the alternator charging. You can buy new plugs with pigtails for about $3 from any auto parts store. Just butt connect it to your existing wires.
Old Oct 16, 2017 | 07:16 PM
sunflower 1972's Avatar
sunflower 1972
Alternator connector with leads: https://www.napaonline.com/en/p/ECHVRC148
To brown wire from alternator
