Wire connector on replacement brake proportioning valve
Old Oct 18, 2017 | 11:02 AM
Dennis Murawski's Avatar
Dennis Murawski
Default Wire connector on replacement brake proportioning valve
I replaced the brake proportioning valve on my 1969 350 convertible. The folks at Ecklers assured me the replacement was identical to the original. Now that it's installed, I find the original wire connector to the switch doesn't fit. I called Ecklers and they were no help. Does anyone know what type of connector I need to find in order to connect to the new valve? Thanks.
Old Oct 18, 2017 | 11:27 AM
MelWff's Avatar
MelWff
can you post a picture of the old and new valves?
Old Oct 18, 2017 | 12:39 PM
Dennis Murawski
I'll try. The original connector was "inset" and slipped over the original switch. The original connector is too small to fit over the new terminal. The new terminal does not stick out as much as the original. If worse comes to worse, my thought was to trim the "skirt" off the original plug. Let me see if I can get some pictures. The new valve is already installed and it may be difficult to get a clear picture.
Old Oct 18, 2017 | 09:12 PM
Bergerboy's Avatar
Bergerboy
Mine was snipped off close to the valve by the P.O.
Probably was getting a BRAKE light that he was getting tired of looking at.
I still have the pigtail with the connector that was left on the valve, but I'd like to hook it back up again.
Where does the other end of that wire eventually connect to? The circuit diagram is hard to read for this circuit, as it also includes the park brake lever switch.
It looks like the wire should route up to the main wire bundle on the left fender inner, but it's not clear where it was snipped off at, and then where it would terminate.
Ultimately, I want to be able to confirm that the valve and sensor are functioning properly.
I've heard that if the valve gets stuck, the light will come on, and you will have dis-proportionate brake pressure front-to-rear.
If the P.O. snipped the wire to make the warning light quit, there may still be the underlying issue remaining.
Old Oct 18, 2017 | 09:27 PM
Dennis Murawski
This is the new valve.
This is the original connector.
This is the original valve.
Old Oct 18, 2017 | 09:35 PM
Dennis Murawski
Originally Posted by Ed T
Do you know if I can buy a new "proper" sending unit?
Old Oct 18, 2017 | 10:07 PM
Dennis Murawski
Take a heads up on the pic I posted to test your old sender {still mounted to the switch) and see how that goes first.
I'd feel better if there were some way to see the switch function. By that I mean under normal pressure read one way and under low pressure read the other way. When you had the sender out of the housing did the plunger end move in and out? Thanks again.
Old Oct 18, 2017 | 11:13 PM
Dennis Murawski
yes, you can feel the action of the plunger by working the jewelers screw driver in and out.
Okay, I pulled the sender out. In this "low pressure" configuration, I'm thinking the switch should allow the wire lead to go to ground and light the brake warning light in the dash. Sitting on the table, my unit is "open." And try as I might, even with pliers, I can't get movement in the switch. The switch should only be open when under pressure, right? Low pressure, circuit closes, dash light goes on. I'm thinking this is a bad unit. Back to trying to find a way to connect the new one. Thanks again, Ed.
Old Oct 19, 2017 | 12:08 AM
Dennis Murawski
Can't get movement on the plunger ? Give the old switch a vinegar douche for a couple days,
It's soaking right now. To be really correct it needs to be a vintage 1969 vinegar, right?
Old Oct 24, 2017 | 04:19 PM
Dennis Murawski
The vinegar soak didn't do squat. I called Ecklers and asked to speak to a supervisor. I asked that they remove the proper sending unit from a 1969 brake proportioning valve in their stock and send it to me. They said they will. We'll see what they send and how difficult it will be to replace in the installed valve.
Old Oct 24, 2017 | 04:38 PM
Alan 71's Avatar
Alan 71
Hi,
It appears Ecklers has sold you the later style switch.
Perhaps Willcox has the switches available if you're not successful with what Ecklers send now?
Regards,
Alan
Old Oct 24, 2017 | 04:46 PM
HeadsU.P.'s Avatar
HeadsU.P.
Vinegar is for coffee makers. Hit that switch with some manly stuff such as PB Blaster.
Evidently that switch wire harness changed design some years ago. I don't believe the P Valve changed much, just the switch. In my opinon, they sent you the wrong P Valve but as I recall, I just swap out the switch with the one that your harness boot will get a weather proof seal on. No worries about brakefluid escaping when removing the switch.
Old Oct 28, 2017 | 12:22 PM
Dennis Murawski
Ecklers followed through. I now have the proper switch. Does anyone need a new '78 - '82 switch? Thanks to everyone that replied.
Old Oct 28, 2017 | 12:30 PM
Alan 71's Avatar
Alan 71
Hi DM,
Hip! Hip! Hooray!
Regards,
Alan
Old Oct 28, 2017 | 02:08 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
I just replaced all my brake lines and the crossover line in the rear on my 82 and now my brake light stays lite. Trying to figure out how to get the light to go out. It appears that you just can't manually move the valve, but use compressed air and then bleed one front and one rear caliper at the same time to center valve on switch. Never heard of doing that nor is it in the GM manual or talk about this issue. Maybe my switch needs replacing? It appears that my rear brakes are locked out. Anybody familiar with this procedure? Thank you.
Old Oct 28, 2017 | 03:00 PM
Dennis Murawski
My new sender has continuity between its tip and plug when not installed, but no continuity between the tip and the attaching nut. So does this mean that under this "low pressure condition" the circuit is open? Is someone willing to put a VOM on a properly functioning switch to see if its tip is grounded? That would mean the brake light comes on when the circuit is broken, right? Then pulling the wire off the sender should turn the brake light on and a broken wire would also turn on the light. I'm soo confused.
Old Oct 28, 2017 | 07:05 PM
HeadsU.P.'s Avatar
HeadsU.P.
You can cancel a stuck brake lite issue by removing the wire. But only as a test. The Prop valve should self-center if there is no difference in pressures between front & back systems by jamming on the pedal, rapidly. To hold it centered while performing brake bleeding you will need the little tool ($12) that replaces the prop valve Switch temporarily.
To Wire connector on replacement brake proportioning valve
Old Oct 28, 2017 | 07:47 PM
Dennis Murawski
So does that mean that the valve does not move in and out but perpendicular to its axis?
Old Oct 28, 2017 | 08:06 PM
HeadsU.P.'s Avatar
HeadsU.P.
I wish I knew how to post pictures of the inards of the Prop valve. Try Google for pix. The valve moves front to back and when it does or I should say if it does due to issues, there is a little nub that triggers or pushes up on the switch (light on)
And the little tool is from PAR? Performance something-something? sorry. Google that too. Proportioning valve tool.
Old Oct 28, 2017 | 11:03 PM
Dennis Murawski
Boy did I have a Bass Ackwards understanding of this switch. I thought it was a low pressure indicator. It's actually an unbalanced pressure indicator. I see that it only closes when the pressure between the front and rear brake lines is out of balance and pushes the "plunger" up or down.. Only then does it ground its terminal and the wire coming off of it. Thanks guys, I learned a lot about brake line proportioning valves.
