c3 front light door - strange corners
Old Oct 20, 2017 | 12:30 PM
dee_lom's Avatar
dee_lom
8th Gear
Default c3 front light door - strange corners
Hi all,
on the picture you can see that the corners upper left and right of my light doors seems a little bit strange. It is as if they have been cut a little bit. Also the door alignment isn't perfect. Why would someone cut a little part off. Or is it just a wrond light door alignment?
Old Oct 20, 2017 | 12:53 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I can't tell whether the openings have been trimmed, but the doors need alignment.
henrikse's Avatar
henrikse
Probably fix with alignment of doors. If you take off grilles and lic plate bracket you will see each door has 3 1/2 bolts holding them at hinge on each side. Now the ones on outside are a challenge to get at. Can only feel them. I took the bumper mount and rod off each side to get access to my arm. You just loosen them a bit and you can adjust up or down and forward. Not a huge amount of adjustment but some.
You can google a pic as I don't have any
Old Oct 20, 2017 | 04:18 PM
Peterbuilt's Avatar
Peterbuilt
As said above.
It might be that the bearings are worn out or the bearing assembly (11) is out of adjustment.
You will have to take a closer look.
Old Oct 20, 2017 | 04:21 PM
Alan 71's Avatar
Alan 71
Hi dl,
Here's one of the bushings that h described.
There are 2 on each door frame that the 'pins' on the headlight door pivot in.
There is some adjustment possible and it often doesn't take much to improve the door fit in the hood surround.
Tough to get to but worth the effort.
Don't want to think this, BUT…. is there any chance the headlight reinforcement beam that's bonded to the underside of the hood surround just to the rear of the headlight openings has come loose? This could be another cause for the lack of fit shown in your photo.
Regards,
Alan
Old Oct 20, 2017 | 05:02 PM
HeadsU.P.'s Avatar
HeadsU.P.
Alan 71. Are those doors reversable? Meaning that they could be on the wrong side.
Or do they need to be rotated 180* in their own opening? Just asking, never had mine off before.
Old Oct 20, 2017 | 05:39 PM
dee_lom's Avatar
dee_lom
8th Gear
when i was watching my photo was thinking the same. will take a closer look soon. Thanx all for the very valuable answers.
Old Oct 20, 2017 | 06:16 PM
Alan 71's Avatar
Alan 71
Hi,
The doors are left and rights, so they're not reversible side to side.
Regards,
Alan
To c3 front light door - strange corners
