SB to BB?
Old Oct 21, 2017 | 02:14 PM
Taijutsu's Avatar
Taijutsu
Default SB to BB?
Like many I spend time thinking about what can be done to make my 74 better/faster.
At some point I think I will have to move up to a BB. A SB has to be pushed too hard.
My question: Is a modern 502 any more trouble than the old 454 to swap into my 74 w/SB?
I know mounts and brackets have to be changed. Would it be the same as the old BB?
The idea of having over 500 hp on tap is appealing!
TIA
R
Old Oct 21, 2017 | 03:43 PM
bence13_33's Avatar
bence13_33
No difference between a 396-502 (or 540 for that matter) dimensionally speaking. You will need to track down brackets, pulleys exhaust manifolds/headers. Distributor, bellhousing, motor mounts, starter are all transferable from a SB to BB.
71VetteLover's Avatar
71VetteLover
TIA
R
It'll drop right in to any of the C3's. The only problem could be the height as a big block will require a big block hood and if it's a big block with a high rise intake it'll require an L-88 style of hood. As the big blocks were an option all of the parts are available to make the conversion. They are tire smokers!
Old Oct 21, 2017 | 04:01 PM
Danish Shark's Avatar
Danish Shark
LS engine is the way to go
Old Oct 21, 2017 | 04:08 PM
vette8121's Avatar
vette8121
1973 and 1974 sb & bb hoods were the same. tm
Old Oct 21, 2017 | 04:21 PM
cv67's Avatar
cv67
St. Jude Donor '05
500ci trumps a sb lsx
Nothing like part throttling yourself past traffic without a sweat. Lots of fun, maybe someday. As you said dont have to push em hard, even one that pulls well to 6k is plenty to get in trouble.
This one had a 460 on the bottle most figured it was just another 5.0 til the light turned green
Old Oct 21, 2017 | 04:22 PM
dmaxx3500's Avatar
dmaxx3500
ive got a couple 588'' BBC engines [fresh,dyno time only],,that would really wake-up that car
Old Oct 21, 2017 | 04:25 PM
Taijutsu's Avatar
Taijutsu
The L-88 hood has always been in the master plan!
An LS motor is being considered. I'm concerned about the amount of fabrication needed?
I'm not set up for that and would have to pay someone else to do it!
I am keeping my options open, but a 502 w/6 speed would be a great
Grand Tourer!
R
Aerovette's Avatar
Aerovette
Aren't the front springs different from SB to BB?
Old Oct 21, 2017 | 04:26 PM
vetski179's Avatar
vetski179
I did a 502 in my Nova. I had a Mark IV BBC 427 in it previously. Everything from the 427 transferred over. One thing to note; I believe all Gen VI BBC's do not have provisions for a mechanical fuel pump. Such was the case on mine. So, an electric fuel pump of some sort is required. I'm very pleased with the 509 (502 + .030), but would've preferred a mechanical pump.
Old Oct 21, 2017 | 04:34 PM
Taijutsu's Avatar
Taijutsu
Default New Driveline?
I can hear the sounds of my SB driveline coming apart w/that much HP.
For the moment I'm trying to upgrade in stages.
I understand that big power requires special and expensive parts.
I'm not ready to join that club just yet! lol
Old Oct 21, 2017 | 06:35 PM
TimAT's Avatar
TimAT
As far as the driveline-- a good hot SB will pop it just as well as a BB will- just maybe not as quick. Face facts- if it hooks up really well with either one, something will break eventually.
Old Oct 21, 2017 | 09:33 PM
cv67's Avatar
cv67
St. Jude Donor '05
Street tires, good Ujoints should live awhile. You can drive a car somewhat hard and not abuse it.
Old Oct 21, 2017 | 09:59 PM
TimAT's Avatar
TimAT
Ol' Red still has the factory installed u-joints and rear end. And it's had 4 different BB's, each one meaner than the last. Rear is coming out this winter. There's too much slop in the stub axles.
Old Oct 21, 2017 | 10:17 PM
71VetteLover
The first thing you'll notice is it'll handle like a Greyhound bus when going around corners; the result of an additional 200+ pounds AND you'll need the stronger big block front springs because of the additional weight.
Old Oct 22, 2017 | 12:33 AM
Taijutsu's Avatar
Taijutsu
Default Perhaps they were wrong?
I had always believed that a BB w/alm heads is #100 lbs more than SB.
No matter how many Alm parts on BB. It will always be a few more than SB.
I believe an LS motor is #50lbs less? I could be wrong.
I'm thinking Old School Grand Touring. High speed cruising in comfort.
R
Old Oct 22, 2017 | 07:41 AM
jb78L-82's Avatar
jb78L-82
A complete cast iron BB will weigh about 650-700 lbs versus a complete cast iron SBC at 450-500 lbs...200 lbs is indeed the difference in weights....its a lot, especially towards the front nose of the car. Of course, you can add aluminum heads, flywheel, intake, radiators, water pump, etc to reduce the weight of either by much as well.
The other issue with the BB is its not just the added weight BUT where the weight is...The BBC in a C3 due to its size is not only much heavier but dimensionally sits slightly forward of the front axle mid line and much higher in the engine bay which adversely effects weight bias front to rear and center of gravity for handling. The typical cast iron BBC C3 back in the day had front to rear weight distribution of:
BBC C3 weight distribution:
Front 52-54%/Rear 46-48% some numbers published are as high as 56% front:44% rear
SBC C3 weigh distribution:
Front 47-50%/Rear 53%-50%
You ideally would want a slight weight bias to the rear like in the C3 SBC for the best handling and Duntov preferred the SBC C3/C2's for this very reason!
With all that stated, why would you want a BBC in your C3 today, when any number of SBC configurations with roller cams, modern aluminum high flow heads like AFR and others along with 10:1 compression on mid grade gas can easily give you the power of a BBC without the weight penalty on the street. You can easily take your 350 block, turn it into a moderate 383 with 525-550 Gross HP/500+ TQ that will make great torque off idle, have monster mid range torque and still will scream to 6,000 RPM! You can build the motor to maximize mid range torque with a moderate duration cam and the correct CC head runners......Think about it!
You will be safe with the stock drivetrain as long as you don't abuse it with 450-500 Gross HP. With my built 355 L-82 4 speed with 3.70 gears, I have avoided clutch dropping at moderate revs from idle and generally roll into the throttle while moving...OEM tranny, rear, and u joints!
To SB to BB?
Old Oct 22, 2017 | 08:21 AM
69ttop502's Avatar
69ttop502
Can’t argue with anything said but no one can argue the wow factor when you pop the hood and see that Rat in there. Never seen that reaction to an LS. Big block any day for me.
Old Oct 22, 2017 | 08:49 AM
dmaxx3500's Avatar
dmaxx3500
''BUT'' when you open the hood,an ''ALUMINUM HEADED BBC'' looks way better then a baby ''SBC''
Old Oct 22, 2017 | 08:58 AM
jb78L-82's Avatar
jb78L-82
I agree with both of guys...the BB wow factor cannot be underestimated^^^^^ but you can today get BB performance from the SB...no question!
