Help decoding 1968
Old Oct 31, 2017 | 06:57 AM
redbuick50's Avatar
redbuick50
3rd Gear
Default Help decoding 1968
Hi, I need an help to decoding engine on a Corvette 1968, numbers on block engine aren't all clear, I ask you if someone can tell me what kind of engine is mounted on this car:
ENGINE #TO215CWR 342..073
VIN #194678S427579
Thanks!
Old Oct 31, 2017 | 07:15 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by redbuick50
...I need an help to decoding engine on a Corvette 1968...TO215CWR...
T Tonawanda (NY) engine assembly plant
0215 February 15th
CWR engine suffix code for a 73-74 454 Corvette engine
Your engine is Corvette, but is not from a 68 convertible. On the pad beside the engine stamp, you should find a VIN derivative stamp for the car the engine was originally installed in.
Old Nov 1, 2017 | 06:01 PM
redbuick50's Avatar
redbuick50
3rd Gear
0215 February 15th
Thanks a lot!
To Help decoding 1968
