4l65e transmission swap.
Old Oct 31, 2017 | 02:49 PM
Niels's Avatar
Niels
Default 4l65e transmission swap.
Is it possible to connect a 4l65e transmission to a 1971 corvette engine.
If so what do i need.
Regards Niels
Old Oct 31, 2017 | 07:51 PM
71 Vert LS1's Avatar
71 Vert LS1
Assuming you have small block the flex plate needs reworking to match the 4L65E torque converter. Also some type computer trans controller. Also you need throttle position sensor off the carb to talk to the ECM.
