Poly Diff Mount Order of Assembly
Old Nov 8, 2017 | 10:47 PM
Neil B's Avatar
Neil B
Default Poly Diff Mount Order of Assembly
Can someone tell me the correct order of assembly in the pic below? Is the large donut the upper or lower bushing? Which washers go where? Thanks.
Old Nov 8, 2017 | 11:41 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
A lot of drawings here:
https://www.google.com/search?q=corv...w=1366&bih=637
Old Nov 8, 2017 | 11:54 PM
81vettski's Avatar
81vettski
Don't know what year your car is but this is for an 81. I'll assume they're all the same. Large donut is the lower mount.
Old Nov 9, 2017 | 12:04 AM
speedreed8's Avatar
speedreed8
Be careful with using the washers in the kit. They are soft metal. I ended up using the original GM washers.
Old Nov 9, 2017 | 12:11 AM
81vettski's Avatar
81vettski
Will do as i will be installing mine shortly. i found a NOS upper cushion cause the 1 I received was so much smaller. Will take a look at the washers and maybe clean up the originals
Old Nov 9, 2017 | 12:45 AM
Neil B's Avatar
Neil B
Originally Posted by claysmoker
The pics online are not consistent.
Old Nov 9, 2017 | 12:52 AM
Neil B's Avatar
Neil B
I assembled it like this. It seemed to fit the best that way.
To Poly Diff Mount Order of Assembly
