Crazy idea
Old Nov 11, 2017 | 06:52 PM
68notray's Avatar
68notray
Default Crazy idea
I need to raise the driver side front just 1/2". Would it be nuts to pull the coil and slide on a length of heater hose?
FWIW I have the 600 lb coils without flattened ends and they are easily removed/reinstalled without a spring compressor
Old Nov 11, 2017 | 07:02 PM
The13Bats's Avatar
The13Bats
Why you want to or need to isnt my business,
Well, some might call is hack job,
But some cars have rubber cushions in the spring pockets,
I have seen ones sold aftermarket to raise a car
https://www.speedwaymotors.com/Speed...BoC1yAQAvD_BwE
so i would likely do it,
But you have to make up your mind if its right for you,
Old Nov 11, 2017 | 07:32 PM
NeverTooOld's Avatar
NeverTooOld
Make sure your tires are fully inflated before doing anything. And if your C3 isn't a daily driver I would just screw a couple of coil spring spacers into that spring. You can get those spacers from AutoZone or Pep Boys.
Old Nov 11, 2017 | 07:38 PM
carriljc's Avatar
carriljc
Go to doc rebuild website and find these:
1963-1982 Corvette Coil Spring 3/8" Spacer Genuine GM 3789664 NOS
or
1963-1982 Corvette Coil Spring 9/16" Spacer Genuine GM 3789665 NOS
I'm reluctant to add a link since I do not know what is acceptable. Note that there are 3/8" spacers and 9/16" spacers.
And speedway also has a 3/4" spacer that states it can be trimmed:
https://www.speedwaymotors.com/AFCO-...ick,23895.html
Old Nov 11, 2017 | 07:39 PM
derekderek's Avatar
derekderek
a heater hose is only about a quarter inch thick and will squish flat in no time. made to hole water in, not weight up...
Old Nov 11, 2017 | 08:19 PM
Cool95vette's Avatar
Cool95vette
I had the typical left side sag in my car. I just replaced the front left spring and it leveled out perfectly. As cheap as springs are I'd rather have a new one rather than try to make a worn out one work.
Old Nov 11, 2017 | 09:23 PM
7T1vette's Avatar
7T1vette
They used to sell little metal twist-in spacers that got inserted between adjacent coils, for "stiffening" (and slightly raising) a weak spring. Normally, one would put two or those in the spring on opposite sides of the spring (to even it up). I'd bet you can still find them at JC Whitney. I think they called them spring extenders or spring stiffeners.
If you can find them, $5 and 5 minutes will fix you up.
Old Nov 12, 2017 | 02:47 AM
The13Bats's Avatar
The13Bats
I used those on a mustang 2 club car i had it raised way more than 1/2 inch,
But did help the worn springs not bottom out,
Old Nov 12, 2017 | 10:10 AM
BLUE1972's Avatar
BLUE1972
I would be careful with the twist in coil spring spacers - over time the spring will bend around the spacer.
Speedway and others sell spacers that fit under the spring to lift the nose. You may be able to find a spring cushion from another car that fits under the spring and gives you the lift you desire.
Since springs are cheap, you could have one made or just purchase a longer spring. A good spring shop can give you a spring that meets your needs.
A final choice would be Coil over shocks. This may / will require some fab work - depending on the choice of shocks. (but totally adjustable)
Old Nov 12, 2017 | 10:15 AM
'75's Avatar
'75
You could just remove the taller spring and flatten the top or bottom of the last coil with a grinder.
Old Nov 12, 2017 | 02:05 PM
bigredbrad's Avatar
bigredbrad
From: Lincoln NE Riding and Driving Corvettes since 1967.
are you sure that both springs are clocked into the lower control arm correctly?
Seen plenty of experts replace them in the wrong orientation and that will affect ride height from left to right side.
bigredbrad
Old Nov 12, 2017 | 03:18 PM
cv67's Avatar
cv67
St. Jude Donor '05
dont use the twist in ones get the ones bat suggested they make them in different thicknesses are cheap and safe.
Old Nov 12, 2017 | 06:13 PM
68notray's Avatar
68notray
Thanks all. I used the proper rubber 3/8 spacer already and it raised that side over an inch so I was just thinking of something to lift it half that much. Springs are not worn out they are new. I'll just go back in it and use the same spacer and cut 1/4 coil off. Thanks, done deal.
Old Nov 13, 2017 | 07:03 AM
2airtime2's Avatar
2airtime2
My '80 came with 3 different tire sizes. It leveled out nicely when I put 4 same sized ones on there. Door gaps got uniform as well.
Old Nov 13, 2017 | 08:34 AM
bashcraft's Avatar
bashcraft
Have you ever seen this happen?
Old Nov 13, 2017 | 10:17 AM
Big2Bird's Avatar
Big2Bird
I tried those as a kid. One popped out on a hard turn, and I almost lost the car. Poor band aid at best.
Old Nov 13, 2017 | 04:40 PM
The13Bats's Avatar
The13Bats
Band aid?
Sure, thats all i needed on that car it was a beater,
I ran my mustang 2 ( hopped up 302 ) with them over 30k dd miles no issues with popping out on a turn or the spring bending around them,
I cant see the spring ever bending around them but if the coils moved and opened right i could see them popping out,
Ive seen them laying in the road where they likely fell out,
Old Nov 14, 2017 | 08:27 AM
68notray's Avatar
68notray
BTW the 3/8" spacer actually measures 9/16" at the thinnest point and is very firm rubber, so they need to rethink advertising them as 3/8"!
To Crazy idea
