ICON Pistons
Old Nov 14, 2017 | 12:04 AM
OldCarBum's Avatar
OldCarBum
Default ICON Pistons
I'm looking at pistons for my 496 build. ICON Performance Pistons manufactures a forged, 30 over piston, that with my 110cc chamber Edelbrock heads will give me about 10.5 to 1 compression ratio. Do any of you run and what do you think of the ICON pistons?
If not the ICON pistons, what forged pistons do you run and with what satisfaction?
Thanks, Greg
Old Nov 14, 2017 | 12:38 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
ICON are good pistons..as are Mahle, SRP, Diamond, probe etc.
Verify the dome fits the small Edelbrock chamber...they are a little different than others.
4032 material will let you run tighter clearances and still have plenty of strength unless you're running heavy N20 or boost.
JIM
Old Nov 14, 2017 | 02:08 AM
OldCarBum's Avatar
OldCarBum
JIM
No N20 or boost. Just building a strong reliable 496.
The performance speed and machine shop I'm working with recommends several including the Mahle, but the ICON has the piston design that will give me as close to the compression ratio I'm trying to achieve.
Old Nov 14, 2017 | 10:11 AM
427Hotrod's Avatar
427Hotrod
What ring thickness? The Mahle's have a nice ring package.
JIM
Old Nov 14, 2017 | 10:35 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I am using ICON pistons in my 1990 race car. Its a mild 355 build with about 350whp. I can spin it to 7000-7200 rpm not problem.
Old Nov 14, 2017 | 11:08 AM
OldCarBum's Avatar
OldCarBum
JIM
I'm not sure. The guy helping me has mentioned Mahle rings and said something about thicker or wider rings holding up better for a street car.
Does that sound right?
Old Nov 14, 2017 | 12:00 PM
curtis75's Avatar
curtis75
I've got ICON pistons in the 427 I built a few years ago. No complaints about them. Its not a real high strung motor but I have had no problems. For what it's worth the machinist mentioned that they were a nice piston as well.
Old Nov 14, 2017 | 12:50 PM
Neil B's Avatar
Neil B
ICON makes a nice piston. As a side note, when I called with BluePrint Engines about a 496 short block, they indicated their current piston vendor is ICON for their forged 496 motor. That is subject to change, but as least you know that piston is going into quite a few motors. I ended up building my 515ci engine locally and went with an SRP piston because they had a 4.560" shelf piston with the right dome volume.
Old Nov 14, 2017 | 02:37 PM
427Hotrod's Avatar
427Hotrod
OEM's are going thinner and thinner on rings each year. While 1/16" ones are common in the Hot Rod world over old 5/64ths....it's common to see 1.0/1.0/3.0mm packages these days (and thinner). Rings are made of much better material these days so thinner works well.
It's all about ring seal. You need to get a round straight cylinder with a torque plate and it has to be honed properly for the rings used.
Attention to detail......
JIM
Old Nov 14, 2017 | 06:54 PM
OldCarBum's Avatar
OldCarBum
JIM
Thanks, Greg
Old Nov 14, 2017 | 11:54 PM
ronarndt's Avatar
ronarndt
I'm also thinking about the ICON pistons, due to price and was glad to see positive comments about them. Some of the other high end forged pistons I am certain are good, but also drain your wallet quicker.
Old Nov 15, 2017 | 12:25 AM
CanadaGrant's Avatar
CanadaGrant
When I rebuilt the original 427 in my 69 I wanted to go with forged pistons so used ICONs and am very happy. When it is cold and for about 2 mins. after starting you can get a very slight even piston rattle that is barely audible due to the forged material and short skirt. This goes away completely as soon as the temp starts to rise. It is very even between all cylinders and is only audible under acceleration while cold. I was actually expecting worse for a big block so was really pleased with the results.
To ICON Pistons
