Distributor rebuild help
Old Nov 18, 2017 | 11:56 PM
69L71's Avatar
69L71
Default Distributor rebuild help
I had a post previously about removing a faulty unilite unit and reinstalling points. I've got everything back to normal with new points, condenser, and lead wire. What I'm having problems with is figuring out where the new ground wire goes. It was missing from the unilite retrofit and all the pictures and fiiguures I've found on the internet are lame.
Can anyone show me a good photo or diagram where it goes?
Old Nov 19, 2017 | 06:01 AM
derekderek's Avatar
derekderek
I don't remember ever seeing a ground wire. points and condenser are screwed to distrib base which is grounded to the block.
Old Nov 19, 2017 | 08:52 AM
redvetracr's Avatar
redvetracr
small ground wire soldered to bottom of points plate to one of the vacuum advance screws
Old Nov 19, 2017 | 10:21 AM
lars's Avatar
lars
Photo shown also has one of my advance limiters installed, but the ground wire installation is correct.
Lars
Old Nov 19, 2017 | 05:38 PM
derekderek's Avatar
derekderek
ok, points plate moves with vac advance, so ground thru greasy bushing kinda iffy. I am too used to boats.
Old Nov 20, 2017 | 01:10 PM
pws69's Avatar
pws69
Canister is is mounted to the distributor housing so ground is solid - not iffy at all.
Old Nov 20, 2017 | 02:01 PM
69L71's Avatar
69L71
Perfect.
Thanks!
To Distributor rebuild help
