Crankshaft align hone?
Old Nov 24, 2017 | 09:08 AM
Vortecpro's Avatar
Vortecpro
I have never heard of bearings with a larger outside diameter to compensate for machining the block.
GM used them, large scale engine rebuilder have used them......only so the caps did not have to be cut to perform a line hone.
Old Nov 24, 2017 | 09:12 AM
Vortecpro's Avatar
Vortecpro
Originally Posted by JoeMinnesota
Align honing does not require machining the caps. It is a HONE, to get everything straight and to the appropriate size. Align boring involves cutting the caps first (to undersize the mains) and then bore back to the correct main size for straightness and uniformity.
As pointed out already, honing is common, boring less-so and more expensive.
"Undersize" (actually, oversized/thicker) bearings are to tighten clearances. Standard .010 or .020 under bearings are to accommodate crank undersize (NOT oversized mains - the O.D. of the bearings should be standard). Cranks are commonly ground at 10 or 20 under to clean up. In my case I used 0.001" undersize bearings on a standard crank to tighten my oil clearances after crank polishing and align honing.
There would need to be a major amount of change in the crank centerline to cause excess slack in a timing chain. I would question whether that's even a possible cause with the small dimensions we're talking about. A change of 0.020" is only 0.010" on a side. There is slack designed in the chain set to begin with, so how much slack do you have? Have you tried a different timing set? Maybe it's the tolerances in whatever set you're using.
"Align honing does not require machining the cap"
That is wrong. It requires machining the cap two different ways when using a conventional bearing.
Old Nov 24, 2017 | 09:14 AM
Vortecpro's Avatar
Vortecpro
So how do they work? .005 smaller diameter sprockets with a tiny bit shorter chain pitch?
The upper gear is bigger in diameter.
Old Nov 24, 2017 | 09:30 AM
PAmotorman's Avatar
PAmotorman
I have seen them for cracked cap PM connecting rods so they can be reconditioned but not mains.
Old Nov 24, 2017 | 09:39 AM
Vortecpro's Avatar
Vortecpro
Ever had a dial bore gauge in the torqued up mains of L31 roller 350 one piece block? If the housing bore was found to be .002 bigger (which is very common) than the high side of the factory spec, how did the assembly line deal with that?
The engine remanufactures had these outside diameter bearings made, they are not available to the public.
Old Nov 24, 2017 | 10:14 AM
PAmotorman's Avatar
PAmotorman
in 40 years of building chevy race engines I never ran across main bearing saddles that needed a larger OD insert. always willing to learn was there a code stamped on the block to show this in case engine repair was needed under warranty??.
Old Nov 24, 2017 | 10:25 AM
HeadsU.P.'s Avatar
HeadsU.P.
Not buying that. Different diameter would change timing events. There is a reason both sprockets are not the same size for example, 2-1 ratio.
Old Nov 24, 2017 | 10:27 AM
Vortecpro's Avatar
Vortecpro
I see over size housing bores from the factory often in BBC and SBC that's why they get lined honed. The bearings are coded, but not available.
Old Nov 24, 2017 | 10:32 AM
Vortecpro's Avatar
Vortecpro
I thought the same thing, upper gear is bigger, but I do believe the lower gear remains the same size. The sets I've seen the upper gear is marked with the lower gear with no marking-.005 or .010. I do understand your point though.
Old Nov 24, 2017 | 10:47 AM
derekderek's Avatar
derekderek
So they are 22 and 44 or 18 and 36 teeth. I guess the chain can handle .001 or .002 bigger distance between the teeth...
Old Nov 24, 2017 | 11:52 AM
HeadsU.P.'s Avatar
HeadsU.P.
The timing chain can handle a lot of thousands. If not, you would never be able to get the camshaft bolts started when installing the sprocket & chain.
A old worn out chain likely has an quarter inch lateral play or more. What would that be equal to on the main bearing vertical clearances?
Old Nov 24, 2017 | 05:26 PM
HeadsU.P.'s Avatar
HeadsU.P.
Summit Racing, Cloyes # 9-130-5 SBC, timing chain only, no sprockets, 0.005" shorter. For use on align bore blocks. $56
Old Nov 24, 2017 | 07:45 PM
  #33
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
Back to OP's engine. Your crank is good? Came out of this block and does not need machined? Then the main bores don't need machined either. It is really only necessary when a main bearing dies and damages the hole it sits in.
Crank is #1182 nitrated forged crank not original to my motor. I had it polished. Rod journals are standard, mains are -0.001.
New set to this motor pink "O" rods with ARP bolts & resized
New set L2304 + 0.030 domed pistons
Rotating assembly balanced to new components
Align hone recommended to create tight true clearances crankshaft rotating assembly
I have no issues with the cloyes double roller I am installing. My initial question was referring to another thread where excessive chain play had developed and the question was asked if the block had a previous line bore or hone.
My question as a result was...When, how much how do you know when a shorter chain or different timing chain is required. I am just looking to better understand what variables this introduces. This is a new topic for me that I had not previously encountered.
Thank you all for the responses
Old Nov 24, 2017 | 10:40 PM
  #34
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I had a Pinto in high school (don't laugh---it ran 14.60's in those days spanking new Z-28's/Trans Am's all day- in fact I still have it!). Anyway, the 2.0L engine had oversized O/D mains from the factory. In fact it had one piston and rod that looked completely different than the other 3 and had a slightly shorter deck height. I was there the day my Dad bought it new with like 5 miles on it...so it came that way from factory. Weird POS but was a running ****!!
JIM
Old Nov 24, 2017 | 11:28 PM
  #35
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Sounds like your engine builder knows what he's doing. Line hone in my neck of the woods runs about $175, good for peace of mind. I wouldn't worry too much about the chain but check it during cam degreeing.
Old Nov 25, 2017 | 07:30 PM
  #36
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
Old Nov 25, 2017 | 07:32 PM
  #37
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
JIM
I remember people doing some crazy motors in the pinto's in High School
