How does one clean the hard fuel lines?
Old Nov 25, 2017 | 06:01 AM
Akroland's Avatar
Akroland
Default How does one clean the hard fuel lines?
I’ve a 1969 l46 coup that sat for a long time prior to my purchase. I’ve had trouble with the fuel system and have replaced all filters, carb and fuel pump. A new gas tank is on order and I’d really like to replace the fuel lines but I’ve read it’s very difficult without removing the body. So, the question is what’s the best method to flush the current lines in place?
Old Nov 25, 2017 | 06:14 AM
NeverTooOld's Avatar
NeverTooOld
Force gasoline through them.
Old Nov 25, 2017 | 06:49 AM
derekderek's Avatar
derekderek
No drain snake exists that could physically scrub the inside of the line. Maybe fill the line with something more volatile, acetone maybe. Let it sit a while. Blow out with compresses air. Then cap the line and pressure test it. Not high pressure. 20 or so psi. But there isn't the volume inside for mass quantities of gluck to settle in like a fuel tank, so any nassness inside should blow out and leave lines decent.
Old Nov 25, 2017 | 08:07 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I blew mine out with compressed air.
Old Nov 25, 2017 | 08:14 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Remove the rubber portion of the lines, flow acetone through the lines, followed by compressed air. Use acetone, because it completely evaporates, and leaves no trace behind, that could contaminate the fuel supply.
(same reason for cleaning wheel bearings with acetone....no residual left behind, to break down the wheel bearing grease)
Old Nov 25, 2017 | 08:41 PM
Lagonia's Avatar
Lagonia
I second acetone. It will completely dissolve fuel related varnish if any exists in the fuel lines. I have used it successfully in other vehicles.
To How does one clean the hard fuel lines?
