C3 Clock Repair
Old Nov 25, 2017 | 06:48 PM
BroncosC3's Avatar
BroncosC3
Cruising
Default C3 Clock Repair
Hello,
My clock doesn't work in my C3, and I'd like to take it apart and figure out how to repair it. I found this thread: https://www.corvetteforum.com/forums...ck-repair.html
however the link to the step by step process appears to be broken. Anyone have an instructive link or directions with images? Thank you,
Old Nov 25, 2017 | 09:04 PM
rberman999's Avatar
rberman999
A long time back I posted to Google “ Jay Ney How I fixed the clock in my 77 Corvetteâ€. I just tried googling the article and it is still up so you should be able to find it. If you look back at my post you will see some notes I added to assist others with their repair. Lots of luck, Russ.
My post in the thread below.
https://www.corvetteforum.com/forums...k-working.html
Old Nov 25, 2017 | 11:52 PM
buns's Avatar
buns
http://www.pcfred.com/Vettetip/FixC3Clock.htm
Old Nov 26, 2017 | 05:51 AM
7T1vette's Avatar
7T1vette
I would highly recommend that you just replace that electro-mechanical clock (Borg) with a modern quartz movement unit. It will look the same, but it will work for many years...and be accurate!
The stock clock is a neat design, but reliability is not one of its virtues. You can fix it...but it will need fixing again in a couple of years. Eventually, a pivot hole in the rear plate will elongate and the clock will be toast. While its out, replace it with something BETTER.
Old Nov 26, 2017 | 09:51 AM
GTR1999's Avatar
GTR1999
I agree with 7T1,
I bought a used quartz white faced clock from a guy 12 -13 years ago when I was going through my 72. It hasn't stopped to date, the only issue with it is the original stem setup where you have to pull it out to change the time, it doesn't always engage. I set it and leave it. I am very happy with it and would be the only way I would service them today. All the original clocks in my 60's cars all stopped working.
Old Nov 26, 2017 | 11:11 AM
C3 4ME's Avatar
C3 4ME
I too upgraded mine to quartz and it hasn't missed a beat since, and it's been years. The only thing obvious unless the kits have changed is the that the second hand sweeps instead of tick tick ticking, if that's something that would bug you.
Old Nov 26, 2017 | 09:06 PM
BroncosC3's Avatar
BroncosC3
Cruising
The quartz clock is $160 from all the ones I've found. I'd much rather try and fix the original as long as it isn't fubar.
Old Nov 26, 2017 | 09:46 PM
lvmyvt76's Avatar
lvmyvt76
don't they have a kit that you can put together instead of buying a complete clock?? cheaper??
Old Nov 26, 2017 | 09:53 PM
rberman999's Avatar
rberman999
If you follow the article by Jay Ney as I suggest then you should be able to get your clock running again unless it has broken parts. Use isopropyl alcohol as the solvent and make sure it is fully dry before lubricanting the movement. I did mine several years ago (3-4) and it shows no signs of failure. I feel mine is original to my 73 so that makes it about 45 years old. The fact that I was able to fixed it myself for a cost of $0 ( I had IPA and a very light machine lube) made me feel good. Report back how you make out. Lots of luck, Russ.
PS: it’s not the only item in my gage cluster I fixed for nothing, I also fixed my amp meter, but that’s a story for another time.
Old Nov 27, 2017 | 07:39 AM
lvmyvt76's Avatar
lvmyvt76
what is up with the weird letters in your post rberman999???
Old Nov 27, 2017 | 08:25 AM
Dynra Rockets's Avatar
Dynra Rockets
What is your time worth?
Being a DIY'er I originally thought I would fix my original clock. Here is my experience....
It is a pain to get out, removing half the dash to get to it. High likelihood of breaking something else while getting it out.
Found the common welded contactors. Separated them and filed flat. cleaned with canned air, lubricated and reinstalled. That took about two solid days work.
Worked great for about a month then blew fuse. Knew the contacts had to have welded themselves again.
Bought a Quartz and installed it. Never looked back and no regrets.
Old Nov 27, 2017 | 11:12 AM
Backstop's Avatar
Backstop
It has to do with the different ways websites handle things like quote marks and dashes. rberman probably copy/pasted from an older website and the CF website doesn't use the same standards.
Old Nov 27, 2017 | 01:08 PM
rberman999's Avatar
rberman999
Hi,
No weird letters showing up in my view of this thread / my reply’s. Using Garage Talk app. with i-phone. Sorry about that.
Addressing the value of ones time in fixing their clock. From my perspective, I looked at it more of a challenge, a learning experience and a level of satisfaction in being able to fix the clock myself at no cost. I now know how the clock works, I have an understanding of how to remove the gauge / radio bezel (up-graded radio, fixed amp gauge and replaced all gauge lamps while I was at it), and the satisfaction of a working clock. All of this has value to me, may not to you. To all contemplating fixing their own clock, I recommend at least trying as you have little to lose and much to gain (again, my perspective). Others will tell you that you’re wasting your time. As my dad use to tell me growing up, “Everyone wants to fell they made the right decision, rather than they made the best decision for themselves from their perspectiveâ€. Lots of luck to those fixing their own clock. Russ.
Old Nov 27, 2017 | 03:28 PM
C3 Stroker's Avatar
C3 Stroker
Nothing wrong with fixing your own clock. It will work, but guaranteed you will be fixing it again...and again....
Buy a new quartz clock once.....end of story. Been there.
Old Nov 27, 2017 | 05:07 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Food for thought.
Old Nov 27, 2017 | 05:58 PM
kansas123's Avatar
kansas123
For me it is all about the sound the original clock makes, the little clunk/thump. Really brings back memories.... Unfortunately my clock is not staying running very many days after the car sits idle like it used to. But it does fire right up when I drive it again, with a little kick start.
Old Nov 27, 2017 | 06:15 PM
shenango's Avatar
shenango
I had my dash out last winter so I cleaned and repaired my clock just to see if it would ever work again. After I put it together I ran it on my end table with a 110 to 12dcv converter for about a week and it ran rather well. When I put the dash back together it sat for about 2 months without the battery hooked up. I was really surprised and happy when I hooked the battery up this spring and the clock started without problems. I did the daily time setting ritual and while it was off 15 or so minutes if the car sat for a week or so, it was nice to hear the clock run. In August the darn thing quit again so it will be non functioning until I have another dash problem to fix. I won't be taking the center dash out just to repair the clock and when I do it will probably get a quartz replacement.
Jerry
To C3 Clock Repair
Old Nov 27, 2017 | 09:43 PM
BroncosC3's Avatar
BroncosC3
Cruising
Dash is already all the way out as I was fixing a different electrical issue. Everything adds up, clock isn't that big a deal to me. I'd just rather spend that money on something else. Seemed dumb to me to spend money on a quartz clock that costs more than the panel I'm putting it in.
Old Nov 28, 2017 | 04:42 PM
0Willcox Corvette
Former Vendor
Jerry
The biggest issue with these old borg clocks is the points burn... and the dirt that gets inside of them. They can be fixed but even then you really are having a crap shoot. This is one reason I did the quartz video, it's a one time deal and works perfectly and the old movements are so susceptible to failure.
On the standard movement write up posted above.. I think it's awesome. But the only thing the guy that did this didn't know was that you can adjust the clock speed by either advancing the clock 12 hours, or reversing it 12 hours. In increments this will make the needed adjustment to the Borg movement over time. While you'll never get it 100 percent accurate, you'll get it very close. In the write up he took the clock back apart (which he didn't need to do).
Willcox
Old Nov 28, 2017 | 06:58 PM
1974ta's Avatar
1974ta
Default 12 hours
Willcox
12 hours plus/minus what ever the clock was off time wise? What if it was off 15 minutes too fast and you advance it 11 hrs. 45 min?
Hope I am making sense. Not trying to hi back a thread but my clock is in need of repair and I will be using the original movement.
Thanks, Bill
