Convert to MANUAL Brakes from Power.
For whatever it is worth:
I have a cowl section that has the area of where the master cylinder goes and I can send you a tracing of this area if needed.
Also....not that this matters. But the pedal assembly on the right in POST#5 shows large square cut-outs. And that is where carriage bolts go and are caged that protrude through the firewall so you bolt up the master cylinder to the firewall using nuts and lock washers. The other two holes have welded on nuts on the back side of them.
DUB
DUB
