Side pipe install - How to ?
Old Dec 9, 2017 | 09:59 AM
SteveG75's Avatar
SteveG75
Originally Posted by Duke94
Plenty of room. I have heat shields on the 78' I used to own and it still clears the door.
Mine clear my hear shields fine. It is right at the rear where the door curves down that you can have an issue, especially if you have some slop in the hinges.
Old Dec 9, 2017 | 10:34 AM
3X2's Avatar
3X2
I'm going from memory when I put a set of Stahl's and Hooker tailpipes on mine about 30 years ago. I bent that tab 90* and bolted it from under the frame rail. There is a T shaped hole that I dropped a bolt and washer down through the T hole and used a rubber cushion on both sides of the tab.
Old Dec 10, 2017 | 03:52 AM
Bangkok Dean's Avatar
Bangkok Dean
Even with shields there is loads of room to clear the doors and the frame is still lower that the pipes.
