1969 Radiator mounting
Old Dec 6, 2017 | 02:31 PM
rangepony69's Avatar
rangepony69
Default 1969 Radiator mounting
OK, time for a dumb question....when I took my 69 apart there was a piece of angle iron (obviously not factory) under the radiator, not touching it, attached by the two mounts, on each side, in the picture.
I can't imagine the radiator needs this support and quite frankly it doesn't directly support the radiator anyway. What are these for? Should the radiator need some support in addition to the two brackets?
Old Dec 6, 2017 | 02:41 PM
20mercury's Avatar
20mercury
Default my speculation, ....
My speculation is that that piece is covering up or was used to repair rust through holes.
Old Dec 6, 2017 | 03:11 PM
CanadaGrant's Avatar
CanadaGrant
It looks like you have rust issues under the paint on the rad support and I imagine somebody was trying to brace up the support.
Old Dec 6, 2017 | 03:18 PM
JoeMinnesota's Avatar
JoeMinnesota
Agreed. Looks like someone used that extra pc to reinforce a rotting lower support. In reality I believe it should be the lower pc that you see exposed, along with a seal/cushion that adheres to the top of it, between the supports. If you remove that extra angle, the bottom rail of the support may be rotted and may fold up. New supports (complete frames) are available, though.
Old Dec 6, 2017 | 04:44 PM
derekderek's Avatar
derekderek
you can see the rust peeking out behind the rad mount bracket...
Old Dec 6, 2017 | 05:39 PM
bazza77's Avatar
bazza77
yes that top piece has been added , looks like as stated to try to give the piece some extra life . That rust is in a tricky spot to get at for sure . The new pieces are expensive but way less hassle than a repair . Decision time for you !
Old Dec 6, 2017 | 08:39 PM
rangepony69
I'll dig into that and see what we have.....car had very little rust in the rest of the frame but under the radiator can be tricky.
Thanks for the help!
Old Dec 13, 2017 | 08:50 AM
rangepony69
Default Update
OK, so I dug into the area behind the right mount...the left was solid. I found a soft spot on the corner of the support....I cut it out and repaired the area with new metal. Nice and solid now.
Thanks for all your help!
RangePony
To 1969 Radiator mounting
