Difference in Moog front springs?
Old Dec 11, 2017 | 09:10 PM
Strokemyaxe's Avatar
Strokemyaxe
Default Difference in Moog front springs?
For a ‘77 they have two springs listed. The only distinction is with or without a/c. Is this just for a weight difference? I can’t imagine the entire a/c system weight more than 60/70 lbs.
if if this is the case, since I’ve switched to aluminum radiator, heads and intake manifold, and still have a/c would this be about the same variance in weight reduction?
Suggestions?
-Stroke
Old Dec 11, 2017 | 09:41 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
if if this is the case, since I’ve switched to aluminum radiator, heads and intake manifold, and still have a/c would this be about the same variance in weight reduction? I've probably complicated things for you since there were actually more different springs originally than just the two choices. This is the reason that some cars ride great with one spring and then you put it in another and it will appear high. (or low)..
Suggestions?
-Stroke
Not in my mind... I'd still run the AC springs.
AC only added 32.50 lbs to the front springs, but I doubt the radiator removed the difference difference. I'd be worried the ride would be too soft with the non a/c springs. I'm no expert on what you are doing so maybe others will offer their opinion.
Willcox
Below I've posted the original 1976-1978 spring chart...
Old Dec 11, 2017 | 09:56 PM
Strokemyaxe
AC only added 32.50 lbs to the front springs, but I doubt the radiator removed the difference difference. I'd be worried the ride would be too soft with the non a/c springs. I'm no expert on what you are doing so maybe others will offer their opinio.
Willcox
Thanks, Willcox man! 32.5lbs for a/c is much less than I had thought it would be. So considering my current weight reduction I do think I’m in the middle row spring of that chart at least.
However, to what spring set does this chart reference? Moog only had two listed. This has three. Are these for the factory dual rate springs?
Much thanks,
-Stroke
Old Dec 11, 2017 | 10:09 PM
0Willcox Corvette
Former Vendor
Much thanks,
-Stroke
Exactly.. that's why I said I may have confused you more... The spring numbers on the chart are the original GM spring numbers which are no longer available. So you either go with the AC or the Non AC springs.. There really isn't another choice available now days.
Willcox.
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
Are those weights in kg rather than lb? I can't make much sense of the total numbers otherwise?
Old Dec 11, 2017 | 10:19 PM
Strokemyaxe
Per wheel, maybe? So times 2 for each?
Old Dec 12, 2017 | 06:05 AM
Metalhead140
Even so would come out around 3100lb for a well loaded rubber bumper car... 1550kg (~3420lb) seems closer on the money?
Old Dec 12, 2017 | 11:16 AM
MelWff's Avatar
MelWff
It states Sprung Weight which is not the vehicle weight.
The mass of the body and other components supported by the suspension is the sprung mass.) Unsprung mass includes the mass of components such as the wheel axles, wheel bearings, wheel hubs, tires, and a portion of the weight of driveshafts, springs, shock absorbers, and suspension links
Old Dec 12, 2017 | 11:30 AM
0Willcox Corvette
Former Vendor
With GM you started with the base sprung weight, then added the option(s) weight to this, the matched the total up with the chart to order the correct spring(s) for the car.
Old Dec 12, 2017 | 02:11 PM
Metalhead140
Ah, now it makes more sense! I hadn't noticed that in the heading. Thanks!
To Difference in Moog front springs?
