Tightening power steering belt for 1971
Follow the sequence detailed in the Chevrolet Chassis Service Manual. If you do your own maintenance on the C3 and you don't have the CCSM, you NEED to purchase one. That document, along with the 1971 AIM (Assembly Installation Manual) are absolute MUSTS for the DIY mechanic.
P.S. If you need to do this adjustment immediately, I'll attempt to type the procedure in a following post. Let me know.
jbakyy (12-17-2017)
Oh procedure, uhoh. My belt so loose and twisting, I got new gates belt. I may tackle sun if it is not to much of procedure. Do I need to take hood off? Thanks
It is a challenging job. There is the adjustment bolt at the 10 o'clock position and the pinch bolt at the bottom FRONT that has to be loosened. Then to tension the belt do NOT pry against the reservoir or the filler neck because they'll bend. Good luck.
jbakyy (12-16-2017)
Can you please help with procedure? Thanks
https://www.howacarworks.com/steerin...ing-drive-belt
jbakyy (12-17-2017)
Here is the major part of the problem, back when these sharks were made, the V pitch of the belt was narrower than the new metric belts, and so the new belts tend to ride on the top of the V sides, not on the entire surfaces....you will see the metric belts ride lower in the V of the pulley, and tend to curve our the backside and wear hell outta the top edges
number one is to find an old SAE type belt, you have to ask and it's been years since I faced this issue....I dunno if they made anymore...
jbakyy (12-17-2017)
Received 2,127 Likes
You really have to get this thing up in the air on ramps. Its the only safe way to get at the bottom bolt. Using a piece of one by two (1X2) stick, jam it between the pump and block and pry. There is no other way and its not rocket science. The wood stick will cause no harm. When you feel the belt is tight, lock 'er down, crawl under and tighten the other bolt, done.
jbakyy (12-17-2017)
Hoping that was a bit of good natured sarcasm.
So I Loosen the 10:00 bolt and bottom front?? I think there is also 8:00 bolt. What is the best way to get to bottom center bolt and tension the belt? Thanks
Thanks, I got ccsm and aim and it's still challenging to figure which bolts to loosen and the best way to pry or tension the belt. Thanks.
Read post 8. Its easy. You are trying to make a mountain out of a mole hill. Two bolts, loosen, install belt, pry pump with stick, tighten bolts. There are only two bolts on the PS pump. But you have to get the car up on ramps to access the bottom bolt.
jbakyy (12-19-2017)
Thanks and I realize that, sorry. I'm starting to think the fan shrouding may not be stock because I can't see the lower front center bolt from under the car. Where's the 2nd bolt, in back of the pump??? I can't see any bolts except I think bracket bolts about 8:00 and 10:00 positions. So when I tighten the belt don't I want to push it towards left front wheel. I am having hard time understanding how using a stick between block and pump is going to tighten the belt. Sorry for being such a ps rookie and pain. Thanks
Read post 14, that's a different opinion
I see why it's so easy for you after looking at your 500 hp motor. Thanks
