Borg Wagner tranny number decoding
Old Dec 18, 2017 | 01:01 PM
Lagonia's Avatar
Lagonia
Default Borg Wagner tranny number decoding
I did verify today that the engine and tranny are indeed correct and match the VIN number of the vehicle. Decoding the engine it was a matter of minutes searching but decoding the manual tranny was not quite able to - looking for a site that explains this number: WC319 which is stamped on the driver's side of the tranny, towards the back and it is vertical (bottom to top).
Need to know whether this is the wide or close ration and the manufacture date.
Thank you.
Old Dec 18, 2017 | 01:49 PM
BKarol's Avatar
BKarol
Here you go: http://pontiacpower.org/BW.htm
Old Dec 18, 2017 | 03:59 PM
BKarol's Avatar
BKarol
You can get a copy of your invoice for $50 here and you will see what transmission the car left the factory with. http://www.gmmediaarchive.com/?page=1.
You would need to check near wc319 ( top to bottom) and find that the partial vin is yours first. This assumes the trans has not been touched.
It will look like this listing the transmission, in my case a close ratio:
Old Dec 24, 2017 | 11:51 AM
Grumpy 427's Avatar
Grumpy 427
How many grooves on the input shaft going around the shaft? My super T 10 i just scored has 3, and its a nodular iron case too. Mine decoded out of a 1979 camaro has a 2.64 first gear in it.
To Borg Wagner tranny number decoding
