Remove center cap
Old Dec 21, 2017 | 04:15 AM
Wibäck's Avatar
Wibäck
Default Remove center cap
Hi guys
I am changing tires on my aluminum rims. I need to get the center cap off to fit the wheel in the balancing machine but they won't budge. I hit them from inside with the back of a hammer but nothing happens. Searched the forum but couldn't find anything.
Help please!
Cheers
Fredrik
Old Dec 21, 2017 | 04:35 AM
croaker's Avatar
croaker
I think you need to tap them in from the outside.
Old Dec 21, 2017 | 06:01 AM
NeverTooOld's Avatar
NeverTooOld
Your center caps have probably been installed with clear RTV on them to help keep them from coming off. Place the handle of a large hammer against the inside then clobber the hammer with your palm. My center caps were so loose I feared i would lose them so I resorted to using clear RTV to keep them on but the RTV does make it more difficult to remove them.
Old Dec 21, 2017 | 06:22 AM
Wibäck's Avatar
Wibäck
They actually rattle a little bit so they are not glued. I should just bang on them from the inside?
Fredrik
Old Dec 21, 2017 | 07:04 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
"Clobber" and "bang" might be extreme, but you will have to pop them out from the back.
Old Dec 21, 2017 | 09:30 AM
Wibäck's Avatar
Wibäck
Originally Posted by HeadsU.P.
Outside. Outside. They install from the inside.
Seems reasonable since hitting from inside seems pointless. I will check in one hour when I get home from work.
What I then don't understand is how I could lose one center cap during a ride a couple of years ago.
Fredrik
Old Dec 21, 2017 | 10:52 AM
Wibäck's Avatar
Wibäck
Default Solved
Oh, now I got it! If I had looked close enough I would have seen three small allen screws holding the cap in place.
Unscrew - pops right out.
Cheers
Fredrik
Old Dec 21, 2017 | 11:00 AM
MAXCO's Avatar
MAXCO
These caps do not install from the inside. I just had my brother change my tires this summer and we removed them with a combination of hitting them on the side on outer side of wheel and hitting from inside as described above. They 100% install on the outside of the wheel.
You can see the clips here and how they would clip on from the outside.
https://goo.gl/images/HrVwHP
Old Dec 21, 2017 | 11:02 AM
MAXCO's Avatar
MAXCO
Cheers
Fredrik
Those are neat. I've never seen ones like that...
Thanks for sharing
Old Dec 21, 2017 | 11:05 AM
Wibäck's Avatar
Wibäck
Thanks for sharing
No problem! Those you linked to are plastic after market replacement ones. I have a set of those, which I will use instead and save my three remaining stock metal ones.
Fredrik
Old Dec 21, 2017 | 11:15 AM
revitup's Avatar
revitup
What years were they metal. My '77 originals are plastic.
I wonder if I could drill & tap them and add set screws.
Old Dec 21, 2017 | 11:23 AM
Easy Mike's Avatar
Easy Mike
...Those are neat. I've never seen ones like that...
They're aftermarket.
Old Dec 21, 2017 | 11:27 AM
Wibäck's Avatar
Wibäck
My car is '75 but I'm not sure the wheels are because the flags look different (1980?).
Mine? Flimsy plastic is original?
Fredrik
Old Dec 21, 2017 | 01:21 PM
HeadsU.P.'s Avatar
HeadsU.P.
Ooops. I missed that one.
To Remove center cap
