Cam and roller rockers
Old Dec 22, 2017 | 04:36 PM
Yellow1977's Avatar
Yellow1977
Default Cam and roller rockers
Hey guys once again!!
I have a 77 l48 with a 600 quick fuel, intake, dual exhaust with headers and a 2500 stall I’m on a budget and was looking for just a little more pep nothing crazy. I was planning on getting a comp cam xtream energy cam and lifter kit with roller rockers (parts below) how do you think will affect the car and has anyone done anything similar if so let me know! All feed back is highly appreciated thank you!!
Old Dec 22, 2017 | 06:05 PM
PainfullySlow's Avatar
PainfullySlow
That is a mild cam choice but should work fine as long as the rest of your valvetrain is set up for it.
For a mostly stock motor I am sure those rocker arms will be ok but that is one of the areas where I usually spend a few more bucks to ensure that you are getting quality. Scorpion makes a decent product at a decent price.
Old Dec 22, 2017 | 06:10 PM
NeverTooOld's Avatar
NeverTooOld
Longer duration camshafts need lower rear end gears because the power band is raised And longer duration camshafts need a higher compression ratio to work right.
Old Dec 22, 2017 | 07:26 PM
Yellow1977's Avatar
Yellow1977
My engine is completely stock other than the modifications listed above. If that is a mild can do you think I should bump it up a notch maybe to this guy?
Old Dec 22, 2017 | 07:42 PM
HeadsU.P.'s Avatar
HeadsU.P.
Scorpion is an excellent product all right but hardly a "few bucks more". A quick search on Summit shows three times the cost compared to those roller tips ($98) you want, at $280. Not money well spent. Could be used instead to purchase a better ignition system to go with your set-up.
Old Dec 22, 2017 | 07:58 PM
Yellow1977's Avatar
Yellow1977
That’s another good question I had in mind. What is a good ignition system for cheap? (Best bang for your buck)
Old Dec 22, 2017 | 09:23 PM
drwet's Avatar
drwet
Any HEI including (probably) the one you already have, with the advance curve optimized for your application. Do a search on this forum to find out what the curve should look like and how to achieve it. It can be done with a stock HEI, although its a lot easier if you spend $500 on an aftermarket distributor.
Old Dec 22, 2017 | 10:46 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
That'd be fine, it's not much more .050 duration than a stock l82 cam. If you would consider fitting some thinner head gaskets to bump up the compression and improve quench a little then that would help with the larger cam too. Personally I would recommend the full roller rockers as well - they are something you can reuse if you do a more serious performance build later too, so I would very seriously consider spending the extra now if you think you might want more later.
Old Dec 23, 2017 | 03:08 AM
OldCarBum's Avatar
OldCarBum
Keep in mind that full roller rockers may not fit under your stock valve covers so you may need to add the additional cost to your upgrade. Crower makes a nice set of stainless full rockers that may fit under the stock covers, but they are pricey.
Old Dec 23, 2017 | 07:02 AM
Dynra Rockets's Avatar
Dynra Rockets
None of the two cams you linked offer springs. The stock L48 springs really cannot do much more lift. Select a cam kit that includes springs.
The issue with adding a cam to an otherwise stock L48 (and written in the thread about 5 below this one) is that with the stock heads and pistons the CR is really low. Select a cam that will keep the dynamic compression as high as possible otherwise you might end up the moving the peak rpm higher up in the band without much of a net HP increase.
If it were me I would increase the CR also. The cheapest and easiest way to do that is with used 58cc L98 heads.
Old Dec 23, 2017 | 08:27 AM
HeadsU.P.'s Avatar
HeadsU.P.
MSD Street Fire comes to mind.
Old Dec 23, 2017 | 08:56 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
For your application, keep the HEI.
Old Dec 23, 2017 | 10:17 AM
PainfullySlow
Budget can quickly get out of hand. As was mentioned, if you are doing a cam and roller rockers it is quite likely that you will need new springs and push rods. If you are doing that you may as well do a thinner head gasket. Cost quickly spirals from there.
My advice would be to keep the HEI which has served many engines with much higher HP well. Do the head gasket and your cam/rockers/springs and call it a day.
Old Dec 23, 2017 | 10:43 AM
gr8t73's Avatar
gr8t73
Several years ago I was in the same boat had a 77 L48 & wasn't happy with the performance. I installed the exact same comp cam and lifters as you mention in your post. Did improve the performance but not like I was hoping. About a year later I found as set of heads from a 70 LT1 that had been rebuilt at a good price. When I installed these heads it really made a major improvement in performance. In my opinion if your looking for decent performance and good streetability that cam and lifters, a good set of heads and an aluminum intake is the ticket.
My 73 currently has a ZZ4 crate engine and I would say my 77 with the above mentioned mods performed just as well as the ZZ4.
Old Dec 23, 2017 | 11:54 AM
Yellow1977's Avatar
Yellow1977
I have high rise valve covers so rocker clearance is not an issue. I’ll most likely keep the stock HEI ignition system as many have said its more than sufficient. Sounds like it’s a good idea to go for the kit with springs, would a timing chain be necessary as well? Does anyone know the stock head gasket thickness? I think I’ll order a .015 shim gasket to bump up the CR just a little. Does anyone recommend a certain head gasket? Can I reuse the stock pushrods that’s what I was hoping to do. What do you guys think about this cam kit?
http://www.jegs.com/i/COMP-Cams/249/K12-242-2/10002/-1
Old Dec 23, 2017 | 12:19 PM
OldCarBum's Avatar
OldCarBum
There are tools you can purchase to determine your needed pushrod length. Buy one and determine if you need longer pushrods. If you are beefing up your cam and springs, I would suggest purchasing better than stock pushrods. Follow the manufacturers suggestions by calling their customer service and talking to their techs.
The HEI you have will work great for your application.
Make sure your new cam and distributor gears and compatible.
Again ask the manufacturers techs.
You have to remove the timing cover, chain and cam gear to swap out your cam, so replace the chain and both gears while inside. Upgrading to a good set will keep things together for years without worry.
Increasing the cr by replacing the head gaskets with thinner ones is a great idea.
If you pull the heads you might as well get them checked out before you put them back on.
Old Dec 23, 2017 | 12:57 PM
NeverTooOld
That's a great street cam but it would do its best with a 10 to 1 compression ratio and lower rear gears like 3.55's.
To Cam and roller rockers
Old Dec 23, 2017 | 01:03 PM
REELAV8R's Avatar
REELAV8R
The stock shim head gasket in the 77 is .017” thick. You Will net no gain by going with a .015 felpro shim gasket.
The stock heads on the 77 are complete junk IMO, so you gains may not be what you are expecting.
The stock pistons have a 17 cc dish volume for any of your CR computations.
My 77 is pushing 440hp with 10.6:1 CR and the stock HEI , no issues, so you can save some money there.
The cams you are looking at have too much duration for what you have in a stock motor, it’ll make for a very lazy bottom end and then little gain up top due to the head flow limitations.
Something in a 256 to maybe 262 advertised duration Is more realistic.
Old Dec 23, 2017 | 01:36 PM
Yellow1977's Avatar
Yellow1977
So can those modifications be made without taking the heads off if new gasket aren’t going to get me anywhere.
Also a cam recommendation would be highly appreciated I can’t find anything with decent lift and a duration like that.
Old Dec 23, 2017 | 02:16 PM
REELAV8R's Avatar
REELAV8R
http://www.lunatipower.com/Product.aspx?id=1982&gid=287
This cam might suit your CR and application. The real CR for the L-48 is about 7.7:1. the 76cc heads run up to 80 or so cc's.
Even this cam would be a lot happier at 8.5 CR vs what the L-48 offers.
The next step down is this cam in the voodoo line and may actually be the best choice.
http://www.lunatipower.com/Product.aspx?id=1981&gid=287
For comparison the stock specs for the L-48 are:
@ .050
Intake - .390 lift / 195 duration
Exhaust - .410 lift / 202 duration
112 LCA
You loose plenty of CR and DCR with these heads and piston combo.
This limits the cam choices quite a bit due to low cylinder pressure.
You can use this calculator to compute your DCR.
https://www.jeepstrokers.com/forum/calculator/
your deck clearance is .025 if the engine is still stock.
