SS Brake Lines
Old Dec 22, 2017 | 08:46 PM
BlackRocket's Avatar
BlackRocket
Default SS Brake Lines
Does anyone have a lead on who makes good SS brake lines that run as one piece from the hard line at the frame to the caliper.
I have a SS flex line from that point to a mount on the trailing arm and then hard line again to the caliper. Would prefer a single line.
Thanks!
Old Dec 23, 2017 | 10:50 AM
gr8t73's Avatar
gr8t73
Thanks!
Is this what your looking for:
http://www.jegs.com/i/Russell/799/69...791+4294828856
Old Dec 23, 2017 | 12:52 PM
NeverTooOld's Avatar
NeverTooOld
Thanks!
I don't think anyone makes such a thing because it's very tight quarters where the steel tubing fastens to the caliper.
Old Dec 23, 2017 | 02:03 PM
kansas123's Avatar
kansas123
I have not heard of anyone having something like that (done). You might be able to have someone special make it but the expense would probably be way up there....
Old Dec 23, 2017 | 04:56 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
Here in Aus there are hydraulic hose suppliers who will also make up custom braided brake lines. Shouldnt be an issue to make the bend if you were able to utilise a right angle or banjo fitting in some way. I'm wondering why you want to though?
Old Dec 23, 2017 | 06:05 PM
kansas123's Avatar
kansas123
Seems to me that the flex line between the trailing arm and the hard brake line going forward, is necessary due to the constant movement of the trailing arm when driving the car. If a single hard line existed between the brake caliper and the connection to the hard line going forward, I don't think the brake line and fittings could take the movements.
Old Dec 23, 2017 | 06:10 PM
dmaxx3500's Avatar
dmaxx3500
the ''right stuff'' in ohio makes the best ss lines ive ever used,,they are double annealed so they flare and bend as good as any regular lines
To SS Brake Lines
