What a valve job should look like...
Received 1,877 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
This pic was posted recently by Mark Jones (VortecPro). As I've mentioned before, I've been to his shop and seen his work. Very meticulous and really cares. He makes big power without spending stupid money because he pays attention to details.
I think a lot of people just looked at the shiny valves but failed to look closely at the imprints of the actual seating surface on the valve.
If you look at the intake valve on the right...see how narrow the seat is vs the exhaust valve on the left. Look at the placement of the seat out near the edge. This is a way to "maximize" the size of the valve seat and get as much area as possible with a given valve. If it was lower on the valve...the "hole" for air to flow through would be just that much smaller even though it had the same size valve as a head with a poor valvejob.
Notice the wider seat on the exhaust valve to help dissipate heat which requires it to be more centered.
Some guy hacking with a valve grinder or even an automated machine doesn't guarantee true craftsmanship.
And we aren't even talking about the work in getting the seats/flow correct on the head itself!
Attention to detail makes the difference in an average one and a "Gee Wow" motor when you stuff your foot in it.
Thanks for posting Mark!
JIM
JIM
The following 6 users liked this post by 427Hotrod:
3JsVette (12-22-2017),
ajrothm (12-24-2017),
Big2Bird (12-22-2017),
C3 Stroker (12-25-2017),
Metalhead140 (12-22-2017),
and 1 others liked this post.
Nice work.
Without taking up an entire page - yes that work looks great. Exhaust seat contact is indeed supposed to be wider, to transfer heat off the valve onto the seat. Intakes don't have that requirement so the contact should be more narrow. Doesn't look like the valves have been back cut, which is another flow trick on the intake. The more difficult work is on the seats themselves, not really hard to make new valves look good - please post a pic of the seats if you have one.
I don't have any of the seats. Just thought the valve shots give a good indicator. The real power is in the seats in the heads of course. Back cuts on valves have to work in conjunction with the rest of the port and combo. They can help low lift flow but not always do as good at higher lifts. Depends on what you need and how much lift you're running on which port. Valve head design impacts that also. Flat or tulip etc. Jim
They do look pretty. The first set I did was on my brother's 74 Camaro back around 1976. They came out pretty well using the valve grinder at my grandfather's service garage. A couple weeks later we pulled the 4 cyl head off my father's old (even at that time) Ferguson 30 tractor. I got the angle set up right and turned the crank to move the wheel. Unfortunately I failed to consider that the Fergie valves were at best 1.00" vs. the 1.94" on my brother's Camaro. Long before the wheel contacted the face of the seat it's edge hit the valve stem and ground into it a nice groove about 1/3 the diameter the stem. What's country boy to do in such a situation? Well if Dad's nowhere in sight you finish the job, pop the valves into the head, and put the head back on the engine. It ran for years after that and it was eventually sold still running. Some people would say this just proves that things were over designed back then. My perspective is that it was properly designed for the foreseeable abuse dished out by the youngsters likely to be using and maintaining it.
Looks like a 30 degree back cut on the intakes. You can see it best on #4 intake just inside #2 valve stem. Back cuts aren't as crucial on exhausts as the only flow being interrupted by the back of the valve is a reversion pulse anyway...
Intake seat picture, intakes valve do have 30 degree back cut.
big difference between a average motor head rebuild.
and when a machinist builds a good set of heads, quality does not come cheap.
Dr. Detroit
Received 3,892 Likes
Jebby
http://www.chevelles.com/forums/13-p...-pictures.html
Dr. Detroit
Thanks Jebby! There was no blending. Check this out:
Wow...288cfm @.550 lift.....now I know why you are making power.....the low lift numbers are furious as well....all from just a well set up head....impressive.Jebby
Very nice work! its attention to detail that makes a relatively simple build work so good.....when people say "wow I cant believe how fast the car is with so little" its the attention to the small stuff that your average weekend thrasher misses. I am a firm believer in the "doing more with less" theory. Top engine builders can build an engine with the same specs as the next guy and it will run circles around the other engine because of little details!
One of my "If I had millions of dollars" thoughts, would be to have a nice big shop with all the necessary machine work to do top notch machine work, and then of course send myself to school to learn how to use them lol!
Amelio (12-29-2017)
Bill
I have a few buddies that have really fast cars a few race competitively and I pick their brain when I can. Like I said before, I wish I had all the tools for machining and the know how to use it. Until then I just befriend people like yourself and get the help I need.
