Getting ready to install the cs144 alternator on my 75, Bought some 4 guage wire to run to the solenoid from the alternator and now looking for a fusible link to put in the wire at the solenoid. What guage fusible link do I need and where can I find. Lowest I have found is 10 guage.
You can use the 10 gauge link with a 6 gauge charging wire. You probably don't need that unless you have a lot of accessories connected to your battery. If you are dead set on the 4 gauge you will need an 8 gauge fusible link.
Something to think about:
For the approximately 7-10 foot circuit you are proposing an 8 gauge wire would handle 65-85 amps. A 6 gauge wire for the same length would easily handle 100 amps at 13.8 volts with minimal voltage drop. The battery should never draw this amount of amperage during normal charging after a start. However you know what additional items you have connected directly to your battery that may require higher amperage going back to the battery over and above what is required for charging.
AND those ranges of current handling are at 70ºF-
Rule of thumb- go with a one size larger wire to handle the higher ambient temperatures under the hood- as higher temperatures increase the wire's resistance and lowers it's current rating.
I've already purchased the 4 gauge wire and connectors. Right now running dual fans and thinking about going to fuel injection. Right now trying to find a place where I can find an 8 gauge fusible link with having to buy 25 feet of it.
Richard
And that is an excellent point Richard. If it is just a charging circuit a 6 is one size larger than needed. But with the possible modifications he mentions later the 4 may be the way to go, especially if he runs the fans and a fuel pump directly from the battery.
