Starter wiring help
Old Dec 26, 2017 | 07:07 PM
pthor's Avatar
pthor
From: I don't do cities N/W Montana & Nor California
Default Starter wiring help
I'm to the starter on my rebuild, it's a Jegs mini high-torque starter.
Looking at the pictures can you tell me with the hookups available on the starter , where do these existing wires connect?
The purple wire is now a blue and the rest I believe are all orange/red.
Please be as basic as possible as this is definitely not my area of expertise!
Old Dec 26, 2017 | 07:53 PM
NeverTooOld's Avatar
NeverTooOld
The two ring terminals with the large 3/8" eyes go onto the top lug and the purple wire goes to the 1/4" male blade terminal. You'll have to cut the ring terminal off that purple wire and crimp a 1/4" female blade terminal onto it. The remaining wire can be cut off or ignored if it's a 1974 or later C3. It would have been for sending 12 volts to the coil for starting.
Old Dec 26, 2017 | 08:28 PM
Peterbuilt's Avatar
Peterbuilt
Default Wrong colors just complicate things!
Connect the RED wires to the big terminal on the new starter.
If purple is now blue it connects to the small terminal on your new starter.
You can test it by turning the key to START and confirm that it only gets 12 volts with the key in START.
The Green is not needed on the new starter so tape it off.
The Black was originally the ground for the wiper and fan motor and connected to a bell housing or starter bolt.
72 schematic:
https://docs.google.com/viewer?a=v&p...GE5N2EzZGI2Mjc
Old Dec 26, 2017 | 08:56 PM
pthor's Avatar
pthor
72 schematic:
Okay,I will give it a go ( fingers crossed) thanks
Old Dec 26, 2017 | 08:58 PM
pthor's Avatar
pthor
Tw, it's a 72 if that matters?
Old Dec 27, 2017 | 02:43 PM
pthor's Avatar
pthor
72 schematic:
The black wire is connected above to an orange does that matter or should I go ahead and ground it?
Old Dec 27, 2017 | 03:36 PM
'75's Avatar
'75
Check to see if the black changes back to black again further up. It looks like someone did some repair work on the harness. That wire should go up and split going to the wiper motor and also the heater blower motor. On mine, I ran and new larger black wire, it makes the blower motor work better.
Old Dec 27, 2017 | 04:00 PM
pthor's Avatar
pthor
I traced the wire, it's spliced with a red wrapped in cloth up top so, I'm assuming that's the original? I will get a pic
Old Dec 27, 2017 | 04:11 PM
pthor's Avatar
pthor
This is the very top
Old Dec 27, 2017 | 05:21 PM
Peterbuilt's Avatar
Peterbuilt
Do not connect the battery yet!
The only 'original' wire that is 'wrapped in cloth' goes to the + side of the coil.
Trace the wire in your picture and find out where it starts and ends.
Black wires are generally ground wires.
Red wires are generally 12 volts positive.
All your different color wires have me confused.
You need a meter or test light.
Old Dec 27, 2017 | 08:26 PM
pthor's Avatar
pthor
I still have the cloth covered wire that connects to the coil - with my new MSD ignition, do I still use that? I swore I read somewhere that it's not needed anymore?
Old Dec 27, 2017 | 09:47 PM
Big2Bird's Avatar
Big2Bird
There has been a bunch of work done on that wiring, and without going to your house, I cannot tell if it's good or crap.
What I can see looks reasonable, but it's too hard to tell.
Old Dec 27, 2017 | 09:50 PM
pthor's Avatar
pthor
It worked fine prayer to the rebuild but with all new parts attached to the old block it's become difficult to figure out what I need and don't need.
Old Dec 28, 2017 | 05:52 AM
lvmyvt76's Avatar
lvmyvt76
you have a wiring nightmare, hope all goes well!!! Ever thought of buying a new wiring harness, saves on the fire extinguisher bill Looks like you are doing some other work on the car since some of the parts look freshly painted. Nice chrome headers etc.
Old Dec 28, 2017 | 12:21 PM
pthor's Avatar
pthor
Originally Posted by lvmyvt76
you have a wiring nightmare, hop all goes well!!! Ever thought of buying a new wiring harness, saves on the fire extinguisher bill Looks like you are doing some other work on the car since some of the parts look freshly painted. Nice chrome headers etc.
Thanks.
I'm down to that one black wire, I think it connected to one of the small solenoid connections on the old starter (One of the few things I didn't take pics of prior to pulling the motor)
I have a local hot rod guy coming over later in hopes he can finger this out...
I'm very close to starting the new motor, installing a new harness at this point would take forever, it's been 9 months ~ I need to drive my Vette something fierce !
Old Dec 28, 2017 | 02:20 PM
Olavo's Avatar
Olavo
3rd Gear
Hello ! My C3 1982 is just clicking the starter, no crank. I'm going to verify it this weekend. Have we some Whatsapp group of C3 ? Would be a good Idea to create one if not available yet?
Old Dec 28, 2017 | 10:27 PM
Peterbuilt's Avatar
Peterbuilt
Hi and welcome!
Start a new post and you will get more replies.
First test and fully charge the battery.
Make sure that you clean and tighten the terminals on the battery.
Clean and tighten the ground connection to the frame, it's under the driver's seat but under the car.
With the battery disconnected clean and tighten the big positive connection on the starter solenoid.
Enjoy your new ride!
To Starter wiring help
Old Dec 28, 2017 | 11:21 PM
CanadaGrant's Avatar
CanadaGrant
Thanks.
The small solenoid connection that goes up from the stock starter to the coil (cloth wire) is not needed if you have converted to electronic or non points ignition. Otherwise if you use a two pole mini starter with points ignition, you will not get a full 12 volts to the coil for starting. If it is cold or your battery is low you will have a no start problem but it will work and you won't notice it until then.
When converting to a two pole mini starter you should simplify things by changing to something like a Pertronix ignition in your stock distributor as there is no 3rd pole provision for the 12v booster wire on the starter. Also,Lectric Limited will sell you a complete stock engine wire harness for about 200 bucks and it kind of looks like you need it.
Old Dec 29, 2017 | 09:14 AM
PainfullySlow's Avatar
PainfullySlow
It looks like the starter stuff is well sorted but this stuck out to me like a sore thumb. I trust that you are going to deal with the swiss cheese cross member before running the car?
Old Dec 29, 2017 | 10:31 AM
lvmyvt76's Avatar
lvmyvt76
no, he wants to get the car running first, then take care of this after the fire
