Energy suspension transmission mount
Has anyone installed an Energy suspension transmission mount 3.1108 on a 1979 with manual trans. I noticed that the original mount was shorter in height than the energy suspension mount. Wanted to know if the height difference would cause any issue. thanks in advance
https://www.summitracing.com/parts/e...saAkLdEALw_wcB
The energy suspension mount has two parts a metal plat which is .177 thick and then the mount which is 1.79 in. So the overall height with both pieces is around 2 in. The original mount is about 1.73 in
I found this thread on the corvette forum.
https://www.corvetteforum.com/forums...ly-mounts.html
https://www.autozone.com/transmissio...80_813716_5934
r16678 (12-28-2017)
Mount
I used that mount on my 70 SS Chevelle. The fan hit the shroud at the top. I put in a new stock transmission mount and the fan is now centered correctly. I have a set of Energy Suspension motor and transmission mounts for sale, cheap. Jerry
Which part 3.158 or 3.1108 did you have a problem with
