lateral runout
Old Dec 27, 2017 | 10:22 PM
keithl1967's Avatar
keithl1967
Default lateral runout
Can anyone tell me where I can purchase a kit for runout shims for the rear rotors?
I have new rotors to put on in the spring, and would like to have the shims on hand (assuming I will need them), so i can do the job all in one day without having to measure, then order, then wait...
Old Dec 27, 2017 | 10:44 PM
GTR1999's Avatar
GTR1999
First you will need to clean, deburr, and clean the mating surfaces. You can buy expensive rotor shims if you like but have a shim kit and punch die that I have used for many many years. Some good old fashioned hardware stores or industrial suppliers will have shim stock sheets in various sizes and is all you will need.
Old Dec 27, 2017 | 10:46 PM
teamo's Avatar
teamo
Summit Racing. They sell shims that are .003 and .006 inches so you'll probably want to measure the runout before you order. These are the disk type that goes over the wheel studs. There are different types of shim stock if you don't want to use the type that they sell at Summit.
Old Dec 27, 2017 | 11:28 PM
TimAT's Avatar
TimAT
Oddly enough, Hobby Lobby has brass sheets that can be trimmed with scissors and are thin enough to make shims.
Old Dec 28, 2017 | 01:46 AM
Reaper19's Avatar
Reaper19
That is exactly what I recently did after GTR1999 recommended making shims. I found brass sheets at Hobby Lobby and used some of my wife's aluminum pans or you can pick some up at the grocery store. You will need to measure the run out first and then make the shims. Easily cut with scissors and you can make the center holes with a drill. Clamp the shim between two pieces of wood, this will keep the shims from distorting and allow you to drill a perfect hole. Some of the run out may only require a piece of aluminum foil or try to clean up the rotor and hub a little more.
Old Dec 28, 2017 | 09:21 AM
Street Rat's Avatar
Street Rat
Available at Rockauto.com https://www.rockauto.com/en/catalog/...tor+shim,13714
Old Dec 28, 2017 | 08:20 PM
edk136's Avatar
edk136
A can or two of Diet Mt. Dew made enough shims to do my whole car.
Eric
Old Dec 28, 2017 | 09:30 PM
Sayfoo's Avatar
Sayfoo
Got my tapered shims at Napa a few yrs ago.
Same as Teamo above.
Old Jan 2, 2018 | 09:30 AM
Dave Witman's Avatar
Dave Witman
Mcmaster and carr Shims from .001 to .005
https://www.mcmaster.com/#catalog/123/3278/=1ayacvq
Old Jan 2, 2018 | 09:51 AM
Street Rat's Avatar
Street Rat
Summit Racing has the shims in stock.
I just purchased a couple of sets.
Old Jan 2, 2018 | 09:52 AM
Street Rat's Avatar
Street Rat
I love that place. They have everything it seems.
Old Jan 13, 2018 | 09:16 AM
Street Rat's Avatar
Street Rat
Moved
Old Jan 14, 2018 | 01:49 AM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
I use .001" steel shim stock and make my own.
Old Jan 14, 2018 | 08:41 AM
cooper9811's Avatar
cooper9811
Napa still carries the rotor shims - just bought some about 2 weeks ago.
To lateral runout
