Mixture Screw Length
Old Jan 7, 2018 | 05:13 AM
terrys6t8roadster's Avatar
terrys6t8roadster
I have a set of those in my jet collection box that came out of my 6210-3. Now running 64s. T
Old Jan 7, 2018 | 07:56 AM
Cavu2u's Avatar
Cavu2u
That's the same model carburetor as this one Terry (6210-3, mfg date 0748). My guess would be a much better gas MPG is obtained with the little jets, but at what cost in performance? I stuck with the Holley Data Sheet spec and replaced mine with 83s (IF I'm reading that itty-bitty print correctly ).
Thanks.
Steve
P.S.: Yes, I read it wrong. 83s are for the Secondary circuit.
Old Jan 8, 2018 | 04:22 AM
terrys6t8roadster
It was getting 21 mpg and didn't notice any performance loss until it picked up some dirt in carb. Then everything went to he--. An easy way to see if primary jets are to small is to drive in first gear 25 to 3000 rpm. If you feel surging in engine rpm increase jet size and retest until no more surging. T
Old Jan 8, 2018 | 07:58 AM
Cavu2u's Avatar
Cavu2u
Thanks for that diagnostics tip Terry.
Steve
