What's wrong with my front suspension?
When I jack the front of the car up off the ground the front tires massively "toe in", it looks like the right front tire is making a left turn and the left front tire is making a right turn. Is this normal? If not, what is causing it? The car is a 69.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Sounds like typical bump steer. There's a kit for C2/C3 cars to change the locations of the outer tie rod pivot to reduce/eliminate the bump steer.
Thanks for the replies so far. There's no play in the steering and all the bushings look good. Nothing is loose but I can't figure this out for the life of me. When the car is sitting on the ground the wheels point straight but when it's jacked up off the ground and the front suspension is hanging both tires point inward (toe in). That can't be the way it's supposed to be, it just can't.
How much change in toe are you getting? The factory suspension will change toe-in ~1/4" PER SIDE when the wheel is at full droop.
Here are some measurements I took when I was addressing bumpsteer (change in toe-in due to suspension travel) on my car. Yes it's really that bad
Just to check for a soft frame - take a measurement between the upper A arm shafts (swivel rods) before you lift it and after its lifted. If the dimension changes greatly that may be your answer.
Be sure you roll the car on the ground, if it's currently lifted to get any pre load out.
Here is the anti-bump steer kit I used, but to gain full benefit of it you need to lower the front of the car.
https://www.vbandp.com/c3-corvette-p...it-detail.html
Here is another kit from Vansteel that takes a slightly different approach to solving the problem.
https://www.ecklerscorvette.com/corv...1968-1982.html
