Connect where?
Where to connect the other end? Under heater controls in center console?
Second question. The rubber hose (half green/half black) with rubber ending. It´s in the wiper compartment and goes out to the engine compartment and about 4" to the center it goes through a grommet and back in. Probably somewhere under the dash I guess.
What is it and where to connect?
1979 L82 4spd
Best regards Björn
Hope u understand my English. (Swedish)
You might want to send a Personal Message to Ernie at Wilcox Corvette. He has a lot of excellent diagrams that may help you trace the line you're talking about. He's also very familiar with the systems you are referring to. He's extremely helpful at getting answers on just such questions as you are asking.
Good luck... GUSTO
The hot water shutoff switch has three connections as it can be installed either normally open or normally closed. It is sometimes not connected properly. Different switch versions were used so connections may not be the same. If you have a hand vacuum pump it's easy to hook up properly: The vacuum source (from the "T" I mentioned) should be closed (hold vacuum) when the button is NOT pressed. Press the button and find which other connection now has vacuum and connect it to the line leading to the valve.
I wish my second language skills were half as good as yours!
I'll say welcome too.
Here's a link to a thread from last year containing some 79 a/c information from Willcox.
You may find it to be of some help to you in addition to what Gusto and Mike suggested.
Regards.
Alan
https://www.corvetteforum.com/forums...this-wire.html
