Is it a Performance or Stock cam?
I just bought a 1971 Corvette with numbers matching stock engine. As I continue to evaluate the car, I am realizing the idle is too rough/lumpy. I was told the engine was completely rebuilt (2 owners ago) with a mild cam.
Question:
I am trying to figure out if the rough idle is being caused by the mild cam, or do I have other problems? Off idle it seem smoother. Carburetor mixture adjustments don't seem to help. Vacuum bouncing between 14-16psi (I think?, need to check again). I never owned a car with a performance cam. How smooth should a mild cam idle? Is there a way to determine if my rough idle is being caused the cam?
I know many people love the lumpy idle, but i hate it :-(
Thanks!
'Mild' is a relative term but even what I consider mild has a bit of a lump to the idle.
Try to get up a video clip...
Interesting idea on measuring the valve lift at the rocker arms. The concept makes sense, but I would love to hear more about this. Proper way to do this, OE specs, comparison to mild cam specs? I really want to get a better idea of what cam I have. I would hate to go all crazy rebuilding everything only to find out my cam was the cause all along. In parallel, ill take a closer look for any vacuum leaks as well as check the points, timing, wires and plugs. As soon as the snow melts, Ill roll the car out and take a video clip of the engine idling.
Any addtion feedback is certaily welcomed.
Cheers!
When the engine is turned manually the hydraulic lifter will collapse when it is on the lobe, so the measurement will be considerably lower than the true lift of the cam.
If you have a "rough" idle with 16 inches of vacuum, you have other tuning issues you need to look at. Verify you are running enough timing - you should be in the low 'teens for initial. Verify your vacuum advance is working, and verify it is hooked up to manifold vacuum. With the vacuum advance hooked up, you should have timing at idle of about 30 degrees. Make sure you do not have any vacuum leaks (very common on Corvettes). Unhook every vacuum hose (including the power brake booster line and PCV) from your carb and plug every vacuum nipple and hole and see if anything changes. If the idle mixture screws do not affect idle (you should be able to kill the engine by screwing them all the way in), you have a carb problem, a vacuum leak problem, ignition problem, or an internal engine problem. Not a cam size issue - a cam needs to be awfully darned big in order to cause a "rough" idle.
Lars
Edit add-on: Measuring the lift of the cam at the pushrod or valve will not tell you anything about the cam's specs that would affect idle quality. Idle quality of a cam is determined by duration, overlap and lobe centers - not lift alone. You can't measure the parameters that determine idle quality with common hand tools with the engine and cam in the car. A valid check, however, would be to verify that all 16 valves are opening (approximately) the same amount: If you have a lobe or two going flat, it will caused the rough idle problem your are describing, and this is not an unusual problem on a new engine. This can be visually observed by removing the valve covers, disconnecting the ignition, and cranking the engine over while visually observing the movement of the rocker arms. Flattened lobes are very obvious with rockers arms that will have noticeably less movement than the other rocker arms.
The more likely cause is a vacuum leak: A vacuum leak will affect low-rpm idle quality, but will smooth out and be less noticeable at higher rpm and under load. A vacuum leak can also make the mixture screws appear to be ineffective.
Lars
Edit add-on: Measuring the lift of the cam at the pushrod or valve will not tell you anything about the cam's specs that would affect idle quality. Idle quality of a cam is determined by duration, overlap and lobe centers - not lift alone. You can't measure the parameters that determine idle quality with common hand tools with the engine and cam in the car. A valid check, however, would be to verify that all 16 valves are opening (approximately) the same amount: If you have a lobe or two going flat, it will caused the rough idle problem your are describing, and this is not an unusual problem on a new engine. This can be visually observed by removing the valve covers, disconnecting the ignition, and cranking the engine over while visually observing the movement of the rocker arms. Flattened lobes are very obvious with rockers arms that will have noticeably less movement that the other rocker arms.
sorry thread starter i don't get it.
there is a missing engine and one that is smooth with a cadence.
I did not realize that a "lower than normal" vacuum at idle (all things being equal) is a possible indicator of a performance cam. Based on all the feedback, I am now thinking my engine is perhaps out of tune. I will start with the basics, confirm correct initial trimming, check for vacuum leaks by plugging all inlets and checking the gaskets. If that does not help, Ill proceed to disassemble the carburetor and give it a good cleaning. Ill provide an update to thread once completed.
Thanks!
To recap the following are some base line specs. Still trying to solve the shaky rough idle.
-Previous owner claims the engine was rebuilt ~2000 miles ago
-Previous owner claims engine has a mild cam which is why engine does not idle smooth (suspecting this was a lie to explain the shaky idle?)
-Carburetor from a 1973 Oldsmobile. Jetting is unknown
-Compression 155 at all cylinder (+/- 5 PSI)
-Plugs look OK
-vacuum now at 12 in
-idle set to 675 (but can also run as low as 550)
I went on to check the idle timing and found it to be set WAAAY too advance (something like 40 BTC). With the vacuum advance disconnected, I set it 10 BTC. This helped improve the rough idle a little, but still not very sooth. Total timing seem to be spot on at about 36 BTC. Now that the timing has been brought down to 10 the vacuum is a bouncy 12 in.hg. To insure I dont have a vacuum leak in the lines, I removed all vacuum lines from the manifold and ports and plugged them, but that did not help. I then proceeded to spray all areas with carb cleaner and found no leak. I tried playing with the mixture but they have little effect unless I screw them in 1 turn before the stop. engine runs the same weather 2 turns out or 7 turns out. One last point. past 1000 the engine does smooth out but still not silky smooth.
I am stumped! Do I perhaps just have a performance cam? should I tackle the carb next? maybe still a vacuum leak somewhere? I welcome another thoughts.
Agaon
