383 - buy vs build?
Anyways, I did a very complete comparison of the total costs of buying vs building a 383. I am looking at a Blueprint 383 (dressed) for $4655 plus all the extra little stuff which comes to $6335. A build starting with a Summit block comes in at $6772. So unless I am missing something, it's cheaper to just by the BP383. Note that this is the upper end of my budget also, and it's really more than I want to spend on my toy but I think I can find the funding (i.e. hide it from the wife
). I also included everything I could think of including tools like a hoist and engine stand in both.I have also done a lot of research on Blueprint engines and I think they are a good choice. There are a ton of people/reviews on Summit and none are bad. They also have a good warranty. I don't have a problem with going that way. I'm just surprised that doing a build wouldn't be cheaper. I also know it totally depends on what parts you are using. I tried to keep the parts mostly in the same ball park. For example, the heads I picked were actually Blueprint H8002K heads.
Here are a couple screen shots of the spreadsheet I used to compare the options.
One other thing that I would say is that I really wanted to build my own engine and I though that would be cool to do, but if it's actually more money that I won't do it.
Thoughts??
OPTION 1 - BUY
OPTION 2 - BUILD
1. I'm not including a distributor because I have a new MSD 8360 and I will use that.
2. I am including a new clutch because the McLeod Street Pro I have is only rated to 300 HP.
I know, I built my 383 over the course of two years.
Mine was closer to $9k all said and done, but my heads were more than twice what you have listed for price.
But I wanted a driver side dipstick, and PCV vented block.
Don't forget Carb, intake, exhaust etc if not using your existing parts.
All the little bits, bolts, hose clamps etc add up.
Pilot bearing, throwout bearing, flywheel, tools. (to align bellhousing, to install oil pump pickup tube, engine stands, hoist rental etc..)
And...shipping on everything....
I can build any small block combo for cheaper than you can buy until you add my labor....sometimes with labor I can beat it....
but I once built engines for a living....so I am biased.
Jebby
If you are using an existing block, reusing parts such as thermostat housing, etc then it is not necessarily a lot more to build it yourself.
I think the Blueprint Engines are a good deal though.
The 502 crate my 69 had in it when I bought it had 7500 miles on it. It used a quart of oil every 400 miles, which was common on those 502’s. I asked around, and found a local race engine builder everyone seemed to recommend. We used the block and crank from my crate but redid everything else. It has been a terrific trouble free engine for 15 years now. Just had him look it over and do a cam change and all was good. He once told me of some of the crate engines he has had in his shop to fix. One 632 from a well know crate supplier was there when mine was. So my advice would be try to use parts from your old engine, maybe buy a stroker crank and bare cylinder heads and find someone really good local to you and build a relationship with them. Let them do the machine work and you can put it together yourself. Good luck!
Bill
Thoughts??
OPTION 1 - BUY
OPTION 2 - BUILD
Or pm C3 Stroker, he's in Ohio and has thread going about his new small block. Maybe his builder can do a 383 for you?
Pardon my ignorance, but what is the practical difference between a two piece and one piece rear seal?
And how does a new crank effect that?
