crossfire timing
Old Jan 26, 2018 | 09:03 PM
Mark Ca's Avatar
Mark Ca
Default crossfire timing
Newbie question. I see in a lot of posts that people advance the timing from 6 to 8-12. Why? If higher is better did GM set it lower for emissions or why? What are the downsides of raising the timing?
Old Jan 26, 2018 | 09:07 PM
Big2Bird's Avatar
Big2Bird
Emissions. Upside: Runs better. Downside: Gotta set it back before smog insp.
Old Jan 26, 2018 | 09:22 PM
terry82's Avatar
terry82
to much timing can make it hard to start .and you can have pinging and knocking .to much knocking will give you reduced power.The knock sensor will reduce power.8-10 works best on my car.
Old Jan 26, 2018 | 10:46 PM
Mark Ca's Avatar
Mark Ca
So no issues with 8-10? When you say it works best, what exactly do you mean? Thanks
Old Jan 27, 2018 | 11:49 AM
terry82's Avatar
terry82
my car starts good ,performs good .no pinging or knock.go up 2 degrees each time and see how it runs.the gas that you are using can make a difference.factory calls for 87. my car likes a midgrade 89
Old Jan 27, 2018 | 06:17 PM
Mark Ca's Avatar
Mark Ca
Thanks Larry, I will do that!
Old Jan 28, 2018 | 12:21 AM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
You should be able to get away with 10*-11*, but if it starts pinging, back it off 1* at a time until it stops. I run 20* on my 383, but it likes that much.
To crossfire timing
