Hooker Sidepipes
Old Jan 28, 2018 | 09:13 AM
benito's Avatar
benito
Default Hooker Sidepipes
Got them installed with NO HELP from the Hooker drawing. I have a degree in Mechanical Engineering and hove NO idea what this Hooker provided drawing is telling me? Is it just me?
Old Jan 28, 2018 | 09:26 AM
edk136's Avatar
edk136
I understand the drawing but the problem is, it appears every car is different when it pertains to mounting the molding and how much, if any need to be cut, so basically it's a trial and error kind of thing anyways. Glad you got yours mounted.
Eric
Old Jan 28, 2018 | 09:43 AM
REELAV8R's Avatar
REELAV8R
I'm with you that drawing makes no real sense. Not to mention where is figure B.
I didn't even bother looking at those direction when I got mine, if there even were any. Just modified as necessary made my own mounting bolts and bolted it up.
Old Jan 28, 2018 | 10:55 AM
benito's Avatar
benito
Eric
Part of the problem was that for my 69, according to the instructions, I did not need to have elongated the slots on the frame. Apparently I have a 68 frame where the slots need to be elongated. Come to find out my 69 was built in October of 68! (Still dont's have any idea what that drawing is trying to tell me!)
Old Jan 28, 2018 | 04:17 PM
Alwyn678's Avatar
Alwyn678
Sad but @ least noe you have the side-pipe sound.
Old Jan 30, 2018 | 12:51 PM
gg521's Avatar
gg521
Why don't you call Hooker?
Old Jan 30, 2018 | 01:06 PM
jersey68l36's Avatar
jersey68l36
I just use the rear mounting to frame and I cut off the ones up stream toward the collectors, so that eliminates the need to trim the rocker at that location.
Old Jan 30, 2018 | 01:19 PM
MelWff's Avatar
MelWff
the drawing is telling you that the black side molding has to be shaped in the front to clear the 4 pipes going to the collector. In the middle and the rear it is telling you the molding has to be shaped in order to clear the bracket that is welded to the side pipe and mounts on the frame. As my wife tells me, I am half a rocket scientist, only 2 years of college aeronautical engineering.
Old Jan 30, 2018 | 06:33 PM
benito's Avatar
benito
No help there.
Old Jan 30, 2018 | 06:37 PM
benito's Avatar
benito
WOW. I thought the drawing was telling something about the pipes and the frame! I feel real dumb now.
Old Jan 30, 2018 | 08:16 PM
edk136's Avatar
edk136
I guess I assumed that you knew the instructions were for the molding.
Old Jan 30, 2018 | 08:35 PM
7t9l82's Avatar
7t9l82
I've put on more than a dozen sets of those in years gone by. Some cars you need to trim the molding and some I never needed too. I'd pull off the back tire and try slipping it in from the rear. You may get lucky and have it go right in. Mine aren't trimmed at all.
Old Jan 31, 2018 | 08:20 AM
stingr69's Avatar
stingr69
Worse part of all - The drawing posted we are all looking at is Figure A intended for a C2 Vette. The Figure B is the drawing for a C3 that is shown on page 2 of the instructions.
Old Jan 31, 2018 | 08:39 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I only needed to trim the left side at the collector only.
Old Jan 31, 2018 | 06:46 PM
Plasticfreak's Avatar
Plasticfreak
Bet it sounds badazz!!!!!!!!
Old Feb 2, 2018 | 12:48 PM
benito's Avatar
benito
Now that they are on. Thank you all very much for the help. The muffler rattles inside the sidepipe at idle rpm. The mounting slots are longer than needed.and the side pipe is driven over the collector. See picture
Do I have to expand the flanges on the muffler to stop the rattles?
Old Feb 2, 2018 | 02:31 PM
MelWff's Avatar
MelWff
there are many different types of inserts, so without knowing which one you picked, it should be a tight fit.
To Hooker Sidepipes
Old Feb 2, 2018 | 02:49 PM
cooper9811's Avatar
cooper9811
Yes - As MelWff said, it should be a snug slip fit - but the last set of Hooker inserts I bought for my side pipes did the same thing. I had to expand the flanges a little at a time until I got the insert to fit.
Old Feb 2, 2018 | 05:08 PM
benito's Avatar
benito
Thank you. They have been on and off so many times its become an easy job.
Old Feb 3, 2018 | 07:00 AM
benito's Avatar
benito
