Won’t start right up
Old Jan 28, 2018 | 12:34 PM
DavidNHarris88's Avatar
DavidNHarris88
Default Won’t start right up
i have a 77 that takes a few turns of the key but then fires right up. I’d like it to fire up smoothly with the first turn of the key. Is it a timing issue? Also it has a throttle body. Any advice is much appreciated
Old Jan 28, 2018 | 01:07 PM
drwet's Avatar
drwet
It has a throttle body? Its been converted to fuel injection?
Old Jan 28, 2018 | 08:07 PM
revitup's Avatar
revitup
Are you pumping the gas a few times first? It'll never start with just the turn of the key.
Old Jan 31, 2018 | 03:55 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If it has a throttle body injection of a C4, mainly 85-88, it should also have a cold start injector which squirted a small amount of fuel into the intake upon start up to insure a quick start. Possibly this injector is there and not working?
Willcox
Old Feb 2, 2018 | 08:52 PM
terry82's Avatar
terry82
find out what throttle body you have.on my car it has the factory throttlebody.i had a similar problem .I had to adj the tps and replace the coil.
To Won’t start right up
