vacuum control
vacuum control
I am trying to test my vacuum control and have a question. If I put the input on #1 and turn the selector to off should I a vacuum. With the unit assembled it won’t hold a vacuum but testing each hose separately you can hear the control open and it will hold a pressure. Do I have a bad selector?
Check the technical section on Wilcox Corvette's website.
I believe I saw the vacuum diagram for the earlier models there.
Good Luck
Craig
Just looked again. There is one for a '74 there.
Good Luck
Craig
Received 2,878 Likes
I have a schematic but what I am trying to find out is with just the selector will it hold a vacuum in the off position. I am connecting the vac pump to the number 1 port. With all the ports connected it will not hold a vacuum. Not sur if the leak is in the selector.
Hi G,
According to the chart when the thumb-wheel is in the OFF position:
Ports 1, 2, 3, 8, 9 should hold vacuum
while
Ports 5, 6 should be vented.
Regards,
Alan
while
Regards,
Alan
