How much vacuum is enough?
Old Jan 28, 2018 | 09:23 PM
drwet's Avatar
drwet
Default How much vacuum is enough?
The new 427 idles with about 12" of vacuum. The headlights work ok - maybe a little slower than before, but I won't be able to try the brakes for a few months until the snow melts. Is 12" of vacuum going to be enough?
Old Jan 29, 2018 | 12:12 AM
TimAT's Avatar
TimAT
I run about 11" with my 496-- haven't got it all dialed in yet, but I don't expect much more. Headlights are really slow- but the vacuum system there is still 69 vintage stuff that's never had anything done to it. The brakes seem fine so far, but I don't have many miles on it yet.
Old Jan 29, 2018 | 12:17 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
in my mind, anything below 10" vacuum is not acceptable,
because of slow headlights, due to lower vacuum.
which also means it will also impact power brakes.
and on corvettes A/c and heater controls, and wipers. my recommendation 10" minimum.
prefer 12 min. on corvettes, this is exactly why I do not install large cam in vehicles,
with a lot of vacuum components, like the corvette.
Old Jan 29, 2018 | 01:48 PM
7T1vette's Avatar
7T1vette
12" Hg should be enough. But, you want to make sure that all vacuum leakages are found and repaired so that you have as much vacuum as your engine will produce. You might also experiment with timing settings. When set for 'performance', your vacuum level may be marginal; but, if you adjust timing a bit, that vacuum level may increase. If so, you could have two markings on your distributor flange: one for performance and one for normal operation (where you have higher vacuum).
Old Jan 30, 2018 | 04:54 PM
REELAV8R's Avatar
REELAV8R
On a nice hot day and in gear I only have about 10.5 to 11.0 inches of vacuum and everything still works fine.
Your vacuum can for timing advance may need to be changed or modified to work at that vacuum.
Old Jan 30, 2018 | 05:06 PM
drwet's Avatar
drwet
Thanks. That had not occurred to me. I will check that.
Old Jan 30, 2018 | 05:40 PM
theandies's Avatar
theandies
I was taught by an old-timer (that's me now ) anything between 10 and 15 and you're good to go.
Old Jan 30, 2018 | 06:31 PM
v2racing's Avatar
v2racing
You guys are missing that as you cruise, even with a big cam and low idle vacuum, the vacuum goes higher. My engine idled at 9 inches in neutral and 7 inches in gear, but when I was cruising anywhere from 2000 rpm to 3000 rpm, the vacuum would go to over 20 inches. If you don't have any leaks and have good check valves on the vacuum tank and brake booster, that vacuum will be there when you need the brakes or need to open the headlights.
My brake worked great and my headlights snapped up. Main thing, no leaks and good check valves!
Mike
Old Jan 31, 2018 | 01:56 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
My 427 idle vacuum is 22 does that mean you guys all have a bigger cam?
Old Jan 31, 2018 | 09:25 AM
6spdg37s's Avatar
6spdg37s
i have a comp cams vacuum canister and vacuum pump on my lsx swapped monte carlo (carb setup with monster cam)
To How much vacuum is enough?
