'82 Fuel Line threads.
Hi All,
I just replaced the metal fuel line between the TBs with a new aluminum setup with a gauge to verify fuel pressure. I had a few leaks so I used Teflon tape (general tape blue roll). I used the littlest bit on the threads and it fixed the problem. Now I'm hearing/reading that was the wrong thing to do. I should have used tape or paste rated for gasoline. The tape I used said 'oil and chemicals'. Now I have to take it all apart in fear that the tape I used may deteriorate and break off and cause major issues down the line. Is the tape I used wrong? What's better tape or paste?
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,926 Likes
The fuel lines are not pipe threads, so they do not seal on the threads - the lines have "inverted flare" connections, and the fuel pressure seals on the flared tube and the conical mating connection. By using teflon tape on the threads, all you did was provide lubrication on the threads so you were able to smoothly torque the fittings properly. You could have done the same thing with some light assembly lube on the threads. At this point, it's irrelevant what you have on the threads - your fittings are now torqued tight enough that the flares are seating and sealing - you are not sealing on the thread tape.
Lars
Lars
Lars
Lars
Thanks for explaining it as you did, its making more sense now.
Yes, it's very important that the inverted flare connections be assembled correctly with no misalignment or binding: The flared tube must seat squarely on the inverted flare "cone" in the mating fitting in order to seal. It's a good idea to fully seat the tube fittings by running the fittings all the way in with your fingers: If you cannot mate the fittings and thread them fully together with your fingers, you have misalignment that should be fixed. Never "pull" the fittings together using a wrench due to the fittings being "too tight." This is a sure indication of misalignment which will cause a leak. And, as noted, always apply a light lubricant to the threads of the fitting and to the back surfaces of the flared tube to eliminate any galling - this will assure proper torque. Good job getting it right!
Lars
Lars
Lars
Lars
Thanks again!
No point in removing the tape. As noted, the tape is simply acting as a thread lubricant and the fuel lines are actually sealing on the flared surfaces now, as they should. The tape and the threads will never be exposed to fuel, so you're in good shape. You did the right thing by loosening everything up to "relax" the tubes and get them properly aligned. You also did exactly the right thing by finger-tightening everything to assure the alignment, and then doing a final snug-down with your wrench. Nice work!
As a side note to this, a lot of the guys running the Tripower setups have a nightmare of a time getting all the fuel lines to stop leaking. The aftermarket reproduction fuel lines look very nice, but the bends and angles are not perfect. People installing all these lines tend to "get the fittings started" on the threads, and then use a wrench to pull everything into position. The results are predictable, with leaks all over the place. It takes a lot of time and effort, but each one of the Tripower fuel lines has to be custom "tweaked" on the bends so that every line can be fully threaded and seated with finger-effort before ever taking a wrench to the flarenuts. It's also important that all the threads be lubricated with a little grease, and that a little coating of grease be applied to the back surface of each flare (the surface that the flarenut rides against). This will assure smooth, proper torque at each connection.
Guys with Q-Jets need to follow the same process when they attach the fuel line to the inlet of the carb: Most aftermarket reproduction fuel lines do not align exactly, and a little hand work is necessary to get the "finger-fit" full seating before tightening. And lube those threads..!
Lars
Lars
