U Joints
Old Oct 12, 2002 | 10:50 PM
thamzid's Avatar
thamzid
Default U Joints
Got a Quote today for replacing the U Joints in the Drive Shaft only for my 81 .
The price was $235 and my question is . Is that a reasonable price. I am getting to damn old and fat to be crawling around under there so have to farm it out .
I know when I need a wrench it is going to take 20 minutes to get out from under there and back under and in that time frame I just say the hell with it.
The morale of this story is don't get old and fat.
Old Oct 12, 2002 | 10:57 PM
Stoge's Avatar
Stoge
Default Re: U Joints (thamzid)
That is WAY too high. I wouldn't spend more than half that.
Old Oct 12, 2002 | 11:03 PM
jerryp58's Avatar
jerryp58
I did mine myself and didn't get a quote, but for just the driveshaft U-joints, that does sound like a lot.
I can't imagine someone charging more than 2 hours labor (I think the driveshaft took me a half hour; I won't talk about how long the half-shafts took :mad ). So based on about $50/hr labor and $15 a piece for the joints, that's about $100 over.
PS -- I can relate to the too old & fat comment. I just did a flush & fill of the cooling system and after about a dozen times of getting on the ground to open & close the petcock and bending over the engine compartment to replace the thermostat (and some vacuum line I broke in the process), I was worn out.
[Modified by jerryp58, 10:07 PM 10/12/2002]
Old Oct 13, 2002 | 12:02 AM
vette69's Avatar
vette69
WAY TOO MUCH!!!!!
Unless you don't mind paying someone close to $200.00 for 1/2 hour of labor. Go buy yourself a set of Brute Force U-Joints and a six pack of beer and enjoy an evening with your car. It take longer to jack up the car than it does to remove and replace the U-Joints.
Just my .02 worth
Old Oct 13, 2002 | 12:15 AM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
thamzid: I can sure sympathize with the too fat and (for me) too old to fiddle with that stuff. Price sounds pretty high though. I agree that it should be around half that amount. Funny how mechanics think "rich bas**rd" when you pull in with a Vette. You can almost see the dollar signs in their eyes and hear the cash register bells ringing in their heads. I have the blissful vision of me lifting off that steel manifold and heads when I replace them with aluminum versions. Thinking about inviting a bunch of my buddies over with a case of beer as a bribe.
Dep...aka Old Geezer
[Modified by Ex-Deputy, 10:17 PM 10/12/2002]
Old Oct 14, 2002 | 10:15 PM
thamzid's Avatar
thamzid
Default Re: U Joints (Ex-Deputy)
Got a Price of $99 and this includes Parts & Labor so guess he has my business. It is a Drive Shaft specialty shop so it should be done right.
Old Oct 14, 2002 | 10:39 PM
jerryp58's Avatar
jerryp58
That definitely sounds better :yesnod:
Hope it goes well; let us know.
Old Oct 14, 2002 | 11:06 PM
Dwayne 76's Avatar
Dwayne 76
Default Re: U Joints (vette69)
WAY TOO MUCH!!!!!
Just my .02 worth
After doing my half shaft U-joints, I would gladly pay $200 US for someone else to do it. It will take 1/2 an hour to do if: the flange bolts arn't rusted, you have a table vise, and you have a friend to help ya. That took me much longer then half an hour.
Old Oct 14, 2002 | 11:31 PM
Stoge's Avatar
Stoge
I think I paid $110 at a drivetrain shop to have a set replaced. Sounds like
you got a better deal this time.
I think a lot of shops see a Corvette pulling in and think... "Corvette... BIG
SPENDER!!!" I know there are times that you get what you pay for, but at
the same time, if we keep going to places that overcharge just because its
a vette, we're only fueling the fire.
Old Oct 15, 2002 | 08:14 AM
jerryp58's Avatar
jerryp58
Default Re: U Joints (Dwayne 76)
Dwayne 76, in my case (and I know I've read others echo this), the driveshaft was a piece of cake compared to the half shafts.
If $230 had been the price for both half shafts (labor & parts), I would have said that was very reasonable.
Old Oct 16, 2002 | 10:27 PM
thamzid's Avatar
thamzid
Default Re: U Joints (jerryp58)
My last reply to this thread. It was not the U Joints after all but something in the Rear End making the Clunking Noise when you let off the Gas and then hit it again. Will change the fliud and put in bottle of additive hopefully this will solve the problem. Doubt it but What the Hey.
Anyhow in this endeavor I did fine a HONEST shop in Tucson, Az .
Simmons Driveline at the corner of Ajo and Country Club He checked everything all out and lubed the U joints and charged me a very reasonable price .
He does not do any Major work on Vettes but if you need somethng else I would Highly recommend him .
On changing the fluid do you just suck the old out and put in the new ??
2 bottles and 1 bottle of additive. I will get the juice form the Chevy dealer.
Old Oct 17, 2002 | 02:31 AM
Stevo81's Avatar
Stevo81
Just paid 250 out the door for ujoints on one half shaft. But I had no time and I knew they would do it right. Don't know parts cost...
Chevy dealer here gets $104/hour shop time and their reputation is not good.
I would do my own driveshaft. Age 55, 6'1", 230 lbs, not too bright.
:cheers:
Old Oct 17, 2002 | 03:36 PM
LT-1 Larry's Avatar
LT-1 Larry
C'mon, man. Half the fun of owning a 'vette is crawling around under it getting greasy. All you need is a taller set of jackstands and an industrial strength creeper.
Old Oct 17, 2002 | 05:16 PM
jackson's Avatar
jackson
I've done plenty of em w/ just a hammer & socket/torch ... as many w/ a press too. Time permitting, nowadays I pull shafts ... I buy ujoints ... take em all to a DS shop & have them R&R ujoints ... If they bend a shaft they bought it.
To U Joints
