Carburetor
Old Feb 4, 2018 | 07:34 PM
KiLLerDeathX's Avatar
KiLLerDeathX
6th Gear
Default [Solved] Carburetor
What would cause my motor to rev up higher when the choke opens
Old Feb 5, 2018 | 11:27 AM
MelWff's Avatar
MelWff
if the choke is too tight and the plugs foul as the choke opens they clear and the rpm will go up but you arent being too specific as to what is happening.
1. How high is the RPM that you are observing?
2. If you blip the throttle does the rpm drop down?
3. What is the idle rpm when fully warmed up?
4. what year, what engine, what carburetor?
