Excessive Coolant Flushing
This, of course, requires you drain the coolant.
When i drained it, as you can probably expect, it was brown and looked pretty terrible. So i went through the normal coolant flushing process. I even opened up the engine block coolant drains on the driver's side.
From what I've read, you are suppose to keep flushing until it runs clear, but I have gone through so many cycles and it still looks brown. I've probably gone through 7 cycles of flushing, and it's still brown. I even pour some extra water through the engine when i drain it to try to get any residue out. Even after drains and just pouring water through, im not able to get the water coming from the block drains to run clear. I usually drain, then pour about 10 gallons through, then refill and flush again.
I took a quick look at the oil, and from what I can tell, there doesn't seem to be any water in it (kind of milk shake like, right?).
It's starting to get ridiculous how many gallon jugs i bring to hazardous material disposal.
At this point I'm not sure what to do. Just keep flushing?
I used the blue devil cleaner and the Prestone. Should i use a different cleaner?
Can i ever expect this to run clear?
One word of warning though - if your coolant was that bad, keep an eye on your heater core. There's a good chance that it's nearing failure, and the flushing and/or back flushing might actually speed up the failure slightly (but not a reason to avoid flushing).
I have a coolant flush T-fitting that was installed by the previous owner, but i do not have the tube that suppose to plug into the radiator cap area. I have been adding the water and flushing solution into this T fitting rather than through the radiator cap.
The problem with using the hose is I dont have a 50 gallon drum for the contaminated flushed water.
I know rusty water isn't hazardous, but this is an original numbers block, and I have to believe if the water is still so brown, there is some other non-rust stuff in there.
Once I flush, refill, short drive, drain, the water definitely has a smell to it. I can't tell if it smells like oil.
If I don't see any water in the oil, is it safe to say there shouldnt be any oil in the coolant?
How can I tell?
When i look at the flush + cleaner made by prestone, it looks like it uses some kind of citric acid and water.
Is there a specific cleaner you can recommend?
For a flush, they don't sell the good old Prestone flush anymore, but wood bleach, oxalic acid, is the same thing. As for the "nuetralizer", I forget what works. Maybe baking soda?
Dom
You need something with a solvent in it to cut the 'muck'; and you need something that will dissolve the lime buildup inside the radiator. Radiator cleaner will do both. Just sayin'.....
