My horn works well when the car is cold. After the engine gets up to running temp and everything under the hood is hot (69 BB), the horn doesn't work or works intermediately.
My best guess is that the relay is going bad. I'll start checking from there first.
Are replacement relays any good? I've had a lot of problems with repo and rebuilt parts, and new china crap parts. Can these relays be serviced?
Anyone else have this problem? What did you find?
The horn relay is in a perfect place to catch all the heat.. I'd go there first. After that, check the ground from the steering column- it goes thru the rag joint. Easy to check-- just make a little jumper wire to go over the rag joint and give it a try.. Or if you have a meter, check resistance between the steering shaft just above the rag to the frame.
GM NOS is best if you can find one. My second choice would be Standard Brand , part # HR-140. Top's Auto (Mom and Pop) can order that for you.
I have replaced the rag joint and I don't remember a jumper in there. I'll check this.
I opened the relay today and it looks good. I did clean up the contacts which are a little pitted. I took off all the connected wires and cleaned them even though they all looked ok. I'll check it all the next time I drive the car and get it hot.
Are you ever going to get back out here to SoCal for another birdrun?
Carefully straighten the retaining tabs on the horn relay cover and remove it. Clean all the contacts with fine wet/dry sandpaper (no more than necessary) and put a little non-conductive grease on them to prevent future contact arcing/burning. Replace the cover and use for another 40 years.
I've been out there a few times, but never had time for much. Worked the Orbis Flying Eye Hospital project- they retired the DC-10 and got an MD-10. The company I work for donated one of our retired DC-10's for interior parts. And then some stuff for 10 Tanker when they were at SCLA. Closest to there I've been the last couple of years is Las Vegas. And that's been infrequent and only a couple of days.
Relays failing to close are lack of current to close the armature.
heat=resistance=lower current=less magnetism=less pull in
Pits are normal. They correspond to craters on the other side. This actually improves contact patch. This is why you need a dwell meter to measure used points.
Cleaning contacts with contact cleaner is good. Any contamination is bad.
You'd rather have conductive stuff laying around an electrical device?? The purpose of it is to 'shield' the contacts from air when connection is made. Inhibits arcing and burning of contacts. Connections are made when the contacts actually touch.
You'd rather have conductive stuff laying around an electrical device?? Nobody said that at allThe purpose of it is to 'shield' the contacts from air when connection is made. Inhibits arcing and burning of contacts. Connections are made when the contacts actually touch.
You must use the horn a lot. I might use mine once a year or so.
Well, yea, 5:58 AM on a Saturday? Not many people to honk at that time.
See you tomorrow at 8:00.
R&R'd the relay. It looked surprisingly good for 49yrs old. Minimal corrosion with a little pitting on the main contact. Even the external wire connections looked good. The 2 push on contacts may have been the problem. They are hard to clean, but a few on/off cycles seems to have helped. Maybe one of them was loose?
Anyway, seems to work now.
Depending on the model year of your car, the horn relay is also used as the 'buzzer' for the ignition key switch (key left in with engine OFF). That puts a lot of cycles on the contacts.
OK, update.
Did a 40 mile drive in 70 deg weather, so the engine compartment got up to normal/hot temp. No horn.
But I did find something. The horn doesn't work with the ignition switch in the run position when hot, but does work in the off position, even when hot. Weird huh??
So now I'm thinking that it's the switch?
'69 model
OK, update.
'69 model
Not familiar with 69 wiring, but could a couple wires on the relay be switched around? (Just sayin....).
OK, update.
'69 model
When you say "run" do you mean the car is running?
IF so - that makes sense- the horn system- relay AND horns are seeing a higher voltage- almost 14 versus 12.5 when the car is not running.
The ignition switch has nothing to do with the horns-relay- wiring.
Like I said- jump the green wire to a 12volt source- the terminal on the horn relay will work fine. With the car off and hot-doesn't work- you have narrowed it down to the horn(s).
That will tell you if is a bad relay or the horn(s)-otherwise you are chasing your tail...
Richard
