Since you just replaced some hoses, my first check would be to see what pressure you have in the system. It's entirely possible that an o-ring or gasket didn't seat properly when the new lines were installed and it's lost some of the Freon.
Can you take it back to whoever charged the system for you and have them check the pressures?
Besides the Freon Pressure Switch is there a relay or something that controls the AC Compressor on & off?
Okay, you say the compressor does not cycle... Do you mean it comes on and stays on, or it doesn't come on at all?
If it does not come on at all, you can try bypassing the switch by running a 12v jumper to the clutch on the compressor. Put the switches on the console into the MAX A/C position before engaging the jumper. If the compressor now runs, it should drag down the rpm a bit and quickly begin cooling. If it does neither of these things, you are probably lacking Freon. In which case do not run the compressor in this fashion for more than a few minutes.
If it does begin cooling, you'll probably want to start checking the electronics. From the electronics in the console, to the pressure switch itself.
Good luck and let us know what you discover... GUSTO
If you pull the connector off the freon pressure switch, you can take a piece of bare #12 solid wire, make a "U" shape, and insert it in the harness connector, and it trips the clutch. ( I keep it in my tool box).
this switch is called the low pressure switch, thus if you are low on pressure, it stops the compressor from running, saving the compressor. There is a sight glass located where you hook up for high pressure readings(on the inner fender close to the firewall), that is useful when charging the system, small bubbles will be present until it is fully charges. But you are not running at all, so nothing will show. Looks like you have a 78 or newer, so you should have the sight glass, like my 76 does. On some of the earlier cars, it was located on top of the receiver drier, you should have a accumulator drier. Most don't know about the sight glass. You can test for 12 volts on the firewall side of the plug that attaches to the small low pressure switch, no 12 volts then, something is wrong towards the selector switch, maybe a fuse?? If 12 volts are present, and it does not start the compressor after jumping the socket, it could be the clutch on the compressor.
Also, check the low pressure port to see if it has an R34 adapter on it. If so, maybe pick up an R34 hose that has a gauge on it. Screw on a bottle of refrigerant-don't pierce the top-and snap it on to the low port. This will show you pressure when compressor not running. It is possible, likely even that there is a slow leak you will have a hard, expensive, dash-ripping-out time locating. If so, 2 or 3 cans of R34 spread out over the year may be the best way to go.
Thanks for the info. I am still running R12 in the system.
