seriously stumped
Old Feb 11, 2018 | 07:46 PM
caryb78's Avatar
caryb78
Default seriously stumped
Cylinders# 8,6,4 are ice cold while 2,1,3,5,7, are firing . I have good fire from the wires, thought maybe wires out of order since I had them off but according to the manual they are in the right order. Engine starts right up, no backfires just rough rough. I did install a low profile vacuum fitting but pulled the carb and looked in the runners. No issues. Pulled valve covers, all are working. Any ideas at all???
Old Feb 11, 2018 | 08:01 PM
dmruschell's Avatar
dmruschell
I would think the next step would be to run a compression test.
Old Feb 11, 2018 | 08:09 PM
Big2Bird's Avatar
Big2Bird
Is your new fitting by 4,6,&8?
Old Feb 11, 2018 | 09:20 PM
Duane4238's Avatar
Duane4238
If you had your wires off, I'd check and make sure that 4,6,and 8 are pushed all the way down into the distributor cap. Also check the inside of the cap and make sure there are no problems there, like broken contacts @ 4,6,8. When you say they are ice cold, are you referring to temperature with a thermal gun at the exhaust manifold, or meaning there is no spark at those plugs? If you have spark but the cylinders are cold, then I'd replace those 3 plugs first. If no spark at the wires, go back to the distributor and check that and then put in a new wire on one cylinder and see if you get spark. Let us know what you find.
Duane
I reread your original post and saw that you had good spark at all the wires. I'd start by replacing the plugs in 4,6,8, and see what happens. Sounds like the problem would start there.
Old Feb 11, 2018 | 10:53 PM
7T1vette's Avatar
7T1vette
Any possibility that The contacts in the distributor cap were mismachined...so that there is too much air gap between those contacts and the rotor contact when it comes around to 8, 4, 3, 6 positions?
I know that I have seen a "Zone" dizzy cap with just that problem. Change the cap to an old one and see if the problem goes away.
Old Feb 12, 2018 | 09:56 AM
BlowAMouse's Avatar
BlowAMouse
Cheep tool box item to safely check spark
Amazon Amazon
Old Feb 12, 2018 | 09:59 AM
REELAV8R's Avatar
REELAV8R
Are those cylinders getting fuel? Pull the plugs, they should be all wet with fuel if they are.
If fuel then check ignition,
If ignition and fuel then check compression.
Should be a pretty strong fuel odor out the exhaust too if you got three cylinders with fuel but not firing.
Old Feb 12, 2018 | 10:16 AM
DaveL82's Avatar
DaveL82
I've only seen this happen during idle when the idle circuit is clogged.
Old Feb 14, 2018 | 07:12 AM
7T1vette's Avatar
7T1vette
Interesting. You could hook up your timing light to see if spark is present at all 8 cylinders. If so, then you have a "fuel" problem.
Old Feb 14, 2018 | 12:49 PM
Duane4238's Avatar
Duane4238
So, 8 members have given their suggestions, all of which should have given you an answer had you used them.
You've never replied. Have you found the problem? Did any of the suggestions help? What have you done? It's quite aggravating when someone posts a question and then disappears. How about letting everyone know?
Duane
Old Feb 14, 2018 | 07:35 PM
HeadsU.P.'s Avatar
HeadsU.P.
Duane
Geeezzzz. Rome took two weeks to build. Give em some time. People have lives to live, things come up.
To seriously stumped
