Brake lights stopped working
Old Feb 21, 2018 | 05:39 PM
lvmyvt76's Avatar
lvmyvt76
OR replace the wiring with a new harness.
Old Feb 21, 2018 | 06:33 PM
DUB's Avatar
DUB
OUCH!...that would mean a new main dash harness. Not that what I say means anything but I would repair it if it were in my shop and the customer did not want to pay me to install a new main dash harness.
Just saying.
DUB
Old Feb 21, 2018 | 08:20 PM
lvmyvt76's Avatar
lvmyvt76
it would just be the turning signal harness, not the main harness that was damaged.
Old Feb 22, 2018 | 06:37 PM
DUB's Avatar
DUB
I have never seen a 'turn signal harness'.
The wring harness that is made into the turn signal is just that. It is made into it.
And if he pinched /damaged the wires that the turn signal connects to....that is a part of the main dash harness.
No saying that there may be one out there...but I have not seem it. The major wiring harness manufactures would not sell a repair for wiring that would make it so you would not buy a brand new harness.
DUB
Old Feb 23, 2018 | 08:54 AM
Triton170's Avatar
Triton170
Body harness is fine. Wires were pinched on the turn signal switch wires between the harmonica connector and where the wires go into the steering column.
Old Feb 23, 2018 | 09:44 AM
henrikse's Avatar
henrikse
You can take the harmonic connecter apart and remove wire clip and slide heat shrink over and then re install clip. Will be fine
Old Feb 23, 2018 | 03:46 PM
Triton170's Avatar
Triton170
That's the plan.
Old Feb 23, 2018 | 05:57 PM
DUB's Avatar
DUB
Originally Posted by Triton170
That's the plan.
YEP...that sounds like it will do the trick.
DUB
