Headers
Old Feb 15, 2018 | 07:55 PM
OldCarBum's Avatar
OldCarBum
Default Headers
I'm looking at several header options for my 73 big block 496.
I came across Sanderson Headers which are a 3/8" flange, 16ga mild steel ceramic coated header.
I'm also looking at Hedman and Hooker super comps.
Hooker and Hedman are long tube headers and I'm worried about ground clearance.
The Sanderson's are a short tube header but I'm wondering if there is any benefit running a short tube header?
Old Feb 15, 2018 | 08:02 PM
ddawson's Avatar
ddawson
The Hedman don't hang down low at all. Not sure about Hookers.
If the headers are not coated inside and out skip it and send them out to be done.
Old Feb 15, 2018 | 08:17 PM
drwet's Avatar
drwet
I have Hooker Super Comp headers on my '79 small block and they are not the lowest point on the car. I know that's no guarantee that the Hooker product for a '73 big block will be the same, so take it for what its worth.
Old Feb 17, 2018 | 07:16 AM
69ttop502's Avatar
69ttop502
The Hooker 1 and 7/8 header has ok ground clearance but stay away from the 2 and 1/8. I tried it and no way it was going to work on my 69.
Old Feb 17, 2018 | 08:18 AM
Grumpy 427's Avatar
Grumpy 427
On a 496, you should be running at least a 2" primary tube. Headman and hooker have been around long enough, that they will have a header that will fit the car well. Is your car going to be the factory ride height/ or have you dropped the car at all with lower profile tires etc.
Old Feb 17, 2018 | 10:58 AM
Street Rat's Avatar
Street Rat
Sanderson Headers are a step up in quality from the others imo.
You just have to be bucks up to purchase them.
Old Feb 17, 2018 | 11:35 AM
Grumpy 427's Avatar
Grumpy 427
In my opinion you will need a full length tube header on that 496. Block huggers are fine for a stock 350, a step up from manifolds.
Old Feb 18, 2018 | 11:24 AM
OldCarBum's Avatar
OldCarBum
I'm going to coil overs front and rear and the entire suspension is being replaced and upgraded.
I am worried about ground clearance, that's why I'm considering going with the Sandersons because they are not a long tube header.
If I can find the right header that won't hang down too low, that would be best.
Old Feb 18, 2018 | 11:29 AM
OldCarBum's Avatar
OldCarBum
Actually their prices are very reasonable compared to others.
One of the biggest issues is finding anyone who make a header for corvette big blocks. Small block headers are easy to find.
Old Feb 18, 2018 | 01:57 PM
ddawson's Avatar
ddawson
You can see the Hedman Headers are the same as the pan. They do not hang down past it.
Old Feb 19, 2018 | 01:57 AM
OldCarBum's Avatar
OldCarBum
That's a great photo. That really helps.
What size tubes and collectors?
Old Feb 19, 2018 | 01:22 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
I hate the 3 bolt collector flanges, there's a new better way but I can't remember the name of it. The flanges are what catch on things.
Old Feb 19, 2018 | 03:17 PM
ajrothm's Avatar
ajrothm
The Hedman 2” headers definitely have the best ground clearance. They are perfect for a 496. You can buy them directly from Jet Hot already coated if you want.
I have the 1 7/8” Hookers and the ground clearance isn’t bad, but the orientation of the 3 bolt flange puts one bolt at 6 o’clock, right where you don’t want it.
The new style 2 bolt “ball” flanges are the way to go but. I haven’t see any available for big block C3s.
Eventually, I’ll be replacing mine with the 2” Hedmans.
Old Feb 20, 2018 | 02:16 AM
OldCarBum's Avatar
OldCarBum
Thanks. I was worries about the 2" tubes and clearance issues near the Borgenson steering box.
I'll give Hedman a call and see what they say and asked if they will be manufacturing two bolt ball flanges for the big blocks any time soon and report back.
Old Feb 20, 2018 | 08:56 PM
ddawson's Avatar
ddawson
Just FYI but the Headman is a ball and flange connection. The plates with the bolts can rotate to any position before and clamp the ball/flange tight.
Old Feb 20, 2018 | 09:14 PM
metal tech's Avatar
metal tech
Flowmaster makes an exhaust kit that has the 2-bolt flanges. Would be relatively easy to cut off the 3-bolt flange and weld the new on. There is also a ball flange kit for about $80 less that maybe an option. Either one could be done at home with a small mig and cutoff wheel in a grinder. I modded a set of headers with 3/8 flanges, merge collectors and v-band flanges and it wasn't that difficult.
To Headers
