Is the tach filter really needed?
Old Feb 19, 2018 | 07:17 PM
Wrecked82's Avatar
Wrecked82
Default Is the tach filter really needed?
Quite a few years ago, replaced the defective tach filter with a replacement. Not, when rpm's go over 2500+, tach just jumps around. Does this mean the tach filter is bad - again. Do I really need one. Did not observe any abnormalities when not having filter. Thinking about going back to no filter again.
Old Feb 19, 2018 | 08:14 PM
BLDun's Avatar
BLDun
When I had not filter on my '76 the tach needle bounced a lot. Put a new filter on it and now it's steady and even.
Old Feb 19, 2018 | 08:37 PM
BKarol's Avatar
BKarol
In my case, 17 years without a filter and no problem with my tach.
Old Feb 20, 2018 | 06:46 AM
TedH's Avatar
TedH
Wire broke at my orig tach filter. Tried running without and the needle went haywire. Fab'd one from Radio Shak parts and it worked for a while. Then, I found a tach filter from a late 70's-early 80's (Monte, Regal, Cutlass) G-body for $25 on eBay and no issues since. Direct replacement parts.
Old Feb 20, 2018 | 07:32 AM
LenWoodruff's Avatar
LenWoodruff
I have a 78. Where is this filter located? I thought this was for radio interference?
Old Feb 20, 2018 | 08:39 AM
BKarol's Avatar
BKarol
Old Feb 20, 2018 | 11:18 AM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Is the tach filter really needed? Well, that depends. If your tach signal is clean, then no. example: Electrical noise generated by a modern HEI ignition system can make tach readings appear erratic. The remedy to this is to add a tach filter to “clean up” the noisy signal, and therefore smooth out the reading on the gauge. Hope this helps.
Old Feb 20, 2018 | 11:28 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
Just depends on how noisy the signal is. I have a MSD HEI ignition module installed in my GM distributor. Haven't had a filter on the car for 15+ years with no issues.
Old Feb 20, 2018 | 12:25 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Like others have mentioned, it depends on the noise of the signal. I have a Mallory electronic distributor in my '71 and no problems without a filter.
Old Feb 20, 2018 | 02:22 PM
Big2Bird's Avatar
Big2Bird
GM is generally not in the habit of installing unneeded parts.
The filter does 2 things.
It filters the HEI output for more accurate display.
It protects the tach circuit board from spikes, etc.
Old Feb 20, 2018 | 02:38 PM
TedH's Avatar
TedH
Looking at the engine from the passenger side fender, it is just forward and below the base of the distributor (between distributor and carburetor). It is much more visible with air cleaner and EGR valve removed.
Old Feb 21, 2018 | 06:39 PM
carriljc's Avatar
carriljc
I had to remove the filter when using the signal from my MSD-6 box. It would read ok up to about 3500 rpm, but as soon as I went above that it would immediately start cycling wildly. I read up on it, removed the tach filter, and it was immediately noticeable on my next outing that the tach no longer bounced, and that it was nice and steady up to my 5800-6000 rpm limit....with no bouncing.
Old Feb 21, 2018 | 07:12 PM
Big2Bird's Avatar
Big2Bird
It IS a requirement with the MSD systems.
Old Feb 22, 2018 | 09:03 PM
C3 4ME's Avatar
C3 4ME
I've been driving my 79 for 13 years and it's never had a filter on it.
Old Feb 22, 2018 | 09:04 PM
C3 4ME's Avatar
C3 4ME
My 79 didn't have one on it when I got it 13 years ago and I've never put on on it. So far so good. Stock HEI ignition.
Old Feb 23, 2018 | 02:44 AM
7T1vette's Avatar
7T1vette
The tach filter has nothing to do with radio interference. It is there to clean out the random high frequency spikes [noise] in the vehicle's DC wiring/ignition system. Do you NEED it? Only if you want to be sure that the tach is reasonably accurate.
Can someone's tach work without "jumping" if it does not have the tach filter installed? ........maybe.......
To Is the tach filter really needed?
